Woodmaxx FM78H vs Woodmaxx FM62H with hammers for Kioti CK3520HST
   / Woodmaxx FM78H vs Woodmaxx FM62H with hammers for Kioti CK3520HST #1
aleksanderw
Kioti CK3520
Planning to buy a flail mower for my Kioti and I am torn between these mowers. FM62 covers width of rear wheels with ability to offset 10-12 in to the outside of right tire. It is kind of weak in my opinion.
Then there is FM78 which allows for plenty of offset which I really like, but Woodmaxx says it requires 30HP PTO minimum which Kioti CK3520 HST does not meet. Initially, I will be cutting a lot of blackberries, small saplings 1-1.5 in to clear some more land an to turn it into pasture. Can Kioti CK3520 HST handle larger FM78H without any problems?
I wish Woodmaxx would make these in 6in increments like some other brands do. I would not have this dilemma.
   / Woodmaxx FM78H vs Woodmaxx FM62H with hammers for Kioti CK3520HST #2
You'll be fine with the FM78. PTO HP recommendations are such a crap shoot because there are so many other variables. IMO this is where your HST will shine vs a gear drive. Slow down in the thick stuff, speed up when you can, and any speed in between that's right for the terrain.
I bought a swing arm flail (like for mowing ditch banks) that just barely covers my tire width and could have definitely gone wider with my CK3510.
Edit to add: I don't know if the WoodMaxx gearboxes have integrated overrunning clutches, but if not and your tractor is electric PTO engagement, you might want one of these: Overrunning Clutch-PTO Overrun Clutch
It will save your integral PTO brake from having to stop all that rotating mass.
Thank you Stan. I have checked with Woodmaxx and both flails gearboxes come with integrated overrunning clutches so no worries there. I have spent afternoon running with a wooden ruler around my property and it seems to me that FM78H will fit with a couple of "maybe not spots". Do you see any disadvantages of going with FM78 ( it is actually 80in wide 920lbs vs FM62 being 65in. 810lbs )?
   / Woodmaxx FM78H vs Woodmaxx FM62H with hammers for Kioti CK3520HST #4
The 3ph is more than capable of lifting both of those mowers. I think it's rated around 1300 lbs at 24 in past the end of the arms. HP wise, I think you'll be fine with either, just go slower with the wider one. Being able to get into a bit of a tighter spot with the smaller one may be a feature that is valuable to you, but that's up to you to determine. Another aspect is the amount of swing when you turn corners. A bigger 3ph mower will require a little more planning since it swings farther out than the tractor.
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A55852)
2012 Crane Carrier...
2020 JOHN DEERE 333G SKID STEER (A52707)
2020 JOHN DEERE...
2018 MACK PINNACLE (A53843)
2018 MACK PINNACLE...
2022 Ligchine Spiderscreed Concrete Screed (A55851)
2022 Ligchine...
2017 Bobcat S650 Compact Wheel Loader Skid Steer (A55851)
2017 Bobcat S650...
2005 Ford F-250 Service Truck (A55852)
2005 Ford F-250...
