Kubota M6060 Cast Iron Rear Wheel Question
/ Kubota M6060 Cast Iron Rear Wheel Question #1
nwut05
Gold Member
SW VA. BRISTOL
New Holland T-1510, T 4.75
Hey, I have been negotiating with a dealer on a used M6060 they have on their used lot. Good shape and deal is almost done. But it has the cast iron rear wheels with radials. I do not know the exact size radials at the moment, but here is my question, The outer rim is mounted to the inside of the cast center ( I will try to post a picture ). The dealer dosent seem to want to swap them to where the outer rim is mounted to the outside of the inner cast rim. I would like it done that way, because of thinking future possible flat repair. If the outer rim is mounted to the outside of the cast rim, I figure that if i had a flat, I could just jack the tractor up, remove outer rim bolts and remove the tire and aouter rim and take it to get fixed. This way i do not have to deal with the weight of the cast iron rim and just leave it on the tractor. The added 4 inches on each side of width is another bonus for my hillsides. Anybody have the cast iron rear wheels mounted this way? is it the right way? like I say dealer really dosen't seem to want to do it, thanks
this is how they are now. all i want them to do is mount outer rim to outside of the cast center instead of inside like this......
/ Kubota M6060 Cast Iron Rear Wheel Question #2
Just notify dealer salesperson if they'll change tire/rim mounting you'll purchase the tractor. I think my M7040 rear cast wheels & rims are mounted similar to your photo. I've never considered it a problem because if rear tire had a flat I'd just have tire repair business come repair the leak. Knock on wood I haven't experienced a flat on those rear tires in 12 yrs or 1800 hrs of operation. Have you ever attempted to "man handle" a rear tire/rim of that size. I have BTDT many times yrs ago when I was employed by an equipment dealer. I have no desire to participate in that DANGEROUS task again & take a chance of that tire/rim falling on ME!!
/ Kubota M6060 Cast Iron Rear Wheel Question #3
Both of my M9's are exactly like the picture (I ordered both with cast centers) and I just had a tube failure on the OS and like you, I had my tire man come out and change it. I would never fiddle with the cast center or the rim, too heavy and too great a chance to get hurt if it falls over.
The rims can be repositioned but I'm sure your dealer don't want to fiddle with them. I suggest having a farm tire outfit with a truck mounted cherry picker do it.
/ Kubota M6060 Cast Iron Rear Wheel Question #4
You do realize that the additional holes in the cast center are for adding even additional weight?
  • Good Post
Reactions: JWR
Thanks I understand the concern with the weight of the outer rim tire, i have a second smaller laoder tracotr to help if that ever happens and thats the only time i would be seeking to test my superman tractor tire changing streghnth. I relly do not have a very good field service tractor tire dealer near me anymore. so it's easier if i just take them to the local co-op for the repair. last time i used a field repair man it was almost 400 bucks and that was no fluid just a remount.....you see where this is going..... if i take it in for repair a flat fix and fluid ia about half that cost...depends on the problem that is
yes i do, but with the cast centers and filled rear tires i think i would be heavy enough.
/ Kubota M6060 Cast Iron Rear Wheel Question #7
Mine must be cheap up here in Michigan. My farm tire guy just charged me 180 bucks for a dismount, replace the failed tube and remount, includes the cost of a new tube and of course came to the farm. I did provide him a ham sandwich and a beverage for his enjoyment as well.
/ Kubota M6060 Cast Iron Rear Wheel Question #8
I Remember when setting the wheels to where the buyer wanted them was part of a tractor sale.
That should be a no brainer type of “throw-in” the dealer should be more than happy to do.
  • Good Post
Reactions: JWR
/ Kubota M6060 Cast Iron Rear Wheel Question #9
Why I never run filled tires. No need. To me, filled tires just cause excessive compaction and crushing of my alfalfa plants which equates to lower yield. If I need additional weight for serious loader work, I put on a rear bale spear and add a round bale out back.
I can see why it was 400 clams now. Filled tires are always more expense to deal with and another good reason not to dismount the rim as well.
/ Kubota M6060 Cast Iron Rear Wheel Question #10
I disagree with your observation, the dealer obviously has a good sense of preservation. Any filled tire of that size, dismounting it can be an exercise in getting hurt, especially if the tire when dismounting deviates at all from vertical. That task is best left to a farm tire service with a truck mounted cherry picker and/or evacuation of the tire liquid first and then refill it after the fact.
/ Kubota M6060 Cast Iron Rear Wheel Question #11
Either way is acceptable.
Tire professionals usually do not remove either wheel or rim from tractor to repair punctures but I change/repair my own (never use liquid ballast) and do so. Accordingly, I, too, would want the rims mounted to the outside of the cast centers.
Yes, set-up and delivery once included mounting tires/rims per customers orders but times are changing.
That is around the cost if i take it to get it fixed the mobile service here is a lot more expensive.
I agree with you completely on this, however to be clear and not get in a ny type of dealer bashing here the tractor i am buying is a 2021 model with 270hrs....so not exactly new just new to me!
They are willing to do it, but they want to charge 250 bucks or 2 hrs shop time to do it....thats 125 an hour shop time....💲💲💲
/ Kubota M6060 Cast Iron Rear Wheel Question #14
Offer $250 less for the tractor.
Problem solved.
Today, 125 an hour shop time is pretty reasonable actually.
Thats the going rate in my area also $125 hr and all dealers are pretty much on par no matter the brand here....
So here is where the dealer left me..they swapped the tires to what they are calling the wide position. For me that is better than the narrow position. However they told me they could not set the outer ring tabs to the outside of the inner rim. They said it is because of the cutouts on the back of the cast rim and those rims only have two settings narrow and wide...They said the cutouts are where the tabs go. I need someone that has experience or factual knowledge with this to tell me why the tabs cannot go on the outside of the inner ring. I have, and can pull images from other kubota tractors with the rings to the outside of the inner rim on a medium setting.
I also have looked in the M6060 owners manual and it tells you the cast rims are an option. But it does not tell you the spacing for those rims or how they should be mounted.
this is what i wanted them to do
/ Kubota M6060 Cast Iron Rear Wheel Question #18
Just buy the tractor and don't worry about a potential flat and making it easier for the tire guy lol.
/ Kubota M6060 Cast Iron Rear Wheel Question #19
Been out here in the boon dox 40+ years now. Had two tractors. NEVER had a flat -KOW. I have ag rims on my M6040 and they are mounted just like the pic posted by the OP.
NO WAY would I ever consider fixing a flat on my tractor. Each rear tire is filled with RimGuard and weighs over 1000 pounds. Besides - I'm just too old for that type of job AND it's too easy to call the local tire store.
Well, that is pretty good luck to not have a flat...Ive had my share over the years and know how things mite go. I do not plan to change a full fluid filled tire either, Just if it is flat or going flat and the fluid level is already dropping anyway....been there done that...I de- beaded a rear tire plowing so fast one time all the fluid passing me in the furrow looked like a small creek.....try getting a tire truck in the plowed field on a hillside so we could use the crane arm to reseat it.. fun day on the farm...been there done that!
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
KAESER COMPRESSOR (A60736)
KAESER COMPRESSOR...
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 367...
2004 VOLVO EC290B LC EXCAVATOR (A62129)
2004 VOLVO EC290B...
2001 International 4000 DT 466E (A60462)
2001 International...
2014 FORD F150 4X4 PICKUP TRUCK (A59906)
2014 FORD F150 4X4...
