2023 New Holland WM 105
   / 2023 New Holland WM 105 #1
mudober
Kioti DK35SE, Belarus 825, New Holland Workmaster 105, New Holland TC30
New tractor to me and the dealer and I didnt discuse the radio. not there fault the way things were going but there is no info, on the radio in the manual does anyone know how to set the clock, i.ve tried eveything i can think of. My radio has the volume control on the right hand side. Thanks
   / 2023 New Holland WM 105 #2
My tractor is still in the shop, otherwise I'd help you. I have a WM120, 2023 model, and suspect the radios are the same. I recall (maybe incorrectly) that there's a button on the left side of the radio that roundabout got me into settings.
Admittedly, the instructions for the radio should be available and clear. I think they source whatever they can find that'll fit in the space, and stick it into the hole. I suspect suppliers change often.
   / 2023 New Holland WM 105 #3
Search YouTube for CenTex Ag. He owned a WM75 and did a video on the radio. Might help.
Seen that it was a different radio. No other tube videos could I find.
   / 2023 New Holland WM 105 #5
What is the brand and model of the radio
I hope it’s not broke down. I have only 20 hrs and no problems hopefully it stays that way
There is no name or model on the radio.
   / 2023 New Holland WM 105 #7
My T4.90 has a Jensen in it you might check the Jensen site see if one matches. Also the directions for the radio were in the back of the operators manual also found them online on the new holland site
Thanks I’ll look at new Holland site
   / 2023 New Holland WM 105 #9
See if hitting or holding down the MENU key gets you somewhere, then using the arrow keys to scroll through or using the volume knob (I think it also can be pushed in to confirm settings). Hope I will have mine back by Friday evening. I'll help further if I get it back, we have the same radio.
   / 2023 New Holland WM 105 #10
That's the same radio in my new Powerstar 120.
I can't even find the clock, much less set the time... 😆
I'll be following to see if someone solves the puzzle.
Leeboy 685 Grader (A47477)
Leeboy 685 Grader...
2004 Honda Civic Coupe (A55758)
2004 Honda Civic...
2012 Chevrolet 2500HD Service Body (A47477)
2012 Chevrolet...
2017 Ford Transit Connect Passenger Van (A55788)
2017 Ford Transit...
10' Wheel Loader Bucket (A50775)
10' Wheel Loader...
2019 Kubota M7060 (A53314)
2019 Kubota M7060...
