Where do you get rid of used hydraulic fluid?
   / Where do you get rid of used hydraulic fluid? #1
SouthernSky
Deville, LA
2013 Kubota L3200DT
Autozone and Advanced will take my used motor oil without question but when i asked them about hydraulic oil they said they couldn't take that.
Where do you get rid of it?
   / Where do you get rid of used hydraulic fluid? #3
Call your local Tractor Supply.
   / Where do you get rid of used hydraulic fluid? #4
All my used motor oil and hydraulic fluid goes into a holding tank in the warm months and gets pumped into my Kleen-Burn waste oil furnace to heat the shop and I never have enough so I have my friends contribute as well.
A fella from Deville LA may not be able to justify buying a waste oil furnace to dispose of a few gallons of hydraulic oil.
   / Where do you get rid of used hydraulic fluid? #5
Between 2 large Kubota's and the truck and 2 cars, I generate a lot of used fluids. Each tractor alone takes 15 gallons on a hydraulic fill, so that is 30 there, every year plus all the crankcase used oil and I still run out about January.
   / Where do you get rid of used hydraulic fluid? #7
Don't know why I didn't think of them. I just called. Used motor oil only.
That's odd, here (Upstate NY) they take both. All goes in the same tank for pickup.
We use some on bonfire piles (1 gallon per bonfire spread across 6-8 "half flake" size pieces of hay around a minivan size bonfire)
Aaron Z
   / Where do you get rid of used hydraulic fluid? #9
Aaron Z
Could be New York vs Louisiana disposal rules, especially post-Katrina when much changed after 300,000 cars were totaled.
As the most toxic state in the country (we flip a coin with New Jersey) I just want to make sure I do my part in keeping the soil and water as clean as it will get. I’m willing to pay a small fee to dump it.
I’m going to call a couple tractor repair places tomorrow to see where they get rid of theirs or whoever picks it up for them.
2016 Snorkel S4732 Scissor Lift (A54865)
2016 Snorkel S4732...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A56138)
2019 INTERNATIONAL...
New/Unused 20ft Bi-Parting Iron Gate (A54865)
New/Unused 20ft...
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
2015 Ford F-350 Dump Truck (A51692)
2015 Ford F-350...
2018 JOHN DEERE 410L BACKHOE (A52706)
2018 JOHN DEERE...
