sd455dan
Elite Member
- Joined
- Oct 23, 2012
- Messages
- 4,791
- Location
- North Idaho
- Tractor
- Rhino 554, Ford 550 TLB (JD X500, MTD, Gilson riding mowers) Ford 3000-Sold
This tractor has always run and started well ,also runs very quiet compared to my Ford 3000- which when cold sounds like it wants to throw the rods through the block:laughing: and yet the Ford has absolutely NO smoke after running a few minutes...
Anyway the tractor has always smoked (unburned diesel) till she warms up, and then there is still a little smoke ... So here we go time to find the cause and hopefully fix it without spending a bunch of money...
Here's a picture of it running after 10 minutes from a cold startup
and after removing the exhaust manifold and starting the engine the smoke is only coming from cylinder 4. as seen here
So got out the diesel compression tester and - after modifying one of the injector adapters to fit got these #s
1) 33o# psi
2) 330# psi
3) 360# psi
4) 280# psi
dug out my next HF tool (leak down tester) and found that # 4 did have a considerable increase in leakage into the crankcase compared with the other cylinders... @ 25psi 1,2,3 were all under 3% #4 was over 40%
all leakage seemed to be getting by the rings no discernible sound in the intake or exhaust ports.
Here is what may have caused part of the problem...
GRRRRR gasket...
Time to pull the head and check out the cylinder wall and pull the piston,
gotta stop- because of me aching back, hopefully dig a little deeper tomorrow...
1) 33o# psi
2) 330# psi
3) 360# psi
4) 280# psi
