ALWAYS check security of pto connection. if in doubt call someone.
/ ALWAYS check security of pto connection. if in doubt call someone. #11
Stupid gets rewarded.
Here was my fix when I did something similarly stupid.
/ ALWAYS check security of pto connection. if in doubt call someone. #12
Thanks for this thread. I've never had a mishap, but I'm gonna be a lot more certain the pto shaft is solid before moving on
I don't normally remove the short shaft from the mid pto
how's that work?
you just leave the pto collar hooked up and pull away from deck? would think hooking back up would have been hard, my 2326 MMM has keyed pto shaft on it.
just curious.
/ ALWAYS check security of pto connection. if in doubt call someone. #14
Dmacleo,
I had made ramps to back over the mower which leaves the collar on the pto.
I then remove the collar if my brain is functioning.
In this situation I left the collar on and didn't switch to the rear pto to till the garden. When I engaged the pto...well the rest is obvious.
I worked with an old cement finisher many moons ago and he would always say "if your gonna be dumb, may as be damn dumb".
Lou
2013 Chevrolet Silverado 1500 Ext Cab Pick-Up Truck (A60352)
2013 Chevrolet...
UNKNOWN  500BBL FRAC TANK (A58214)
UNKNOWN 500BBL...
2008 Volvo XC90 AWD SUV (A59231)
2008 Volvo XC90...
TEREX TH8440 TELEHANDLER (A60736)
TEREX TH8440...
UNUSED 2026 INDUSTRIAS AMERICA HYD TITL TRAILER (A60430)
UNUSED 2026...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A60430)
2006 TRAIL KING...
