Has anyone used gear oil in front axle (instead of the hydraulic oil that the manufacturer recommends) AND had an issue?
   / Has anyone used gear oil in front axle (instead of the hydraulic oil that the manufacturer recommends) AND had an issue? #1
disney
Gold Member
orlando fl
scag turf tiger 61" #2, gx95, sold f525 twice, f725 sold
Florida rodent (resident) so not likely to have any issues with gear oil being to thick when below freezing... Thank you in advance for sharing your knowledge and experience.
   / Has anyone used gear oil in front axle (instead of the hydraulic oil that the manufacturer recommends) AND had an issue? #2
You won't get any issues using either. Gear oil is preferred for some high speed applications, but I wouldn't be concerned with it in a tractor. At the low speed of most tractors (8 to 25 mph range) hydraulic oil does just fine.
   / Has anyone used gear oil in front axle (instead of the hydraulic oil that the manufacturer recommends) AND had an issue? #3
As a dealer in Southern California, we used gear oil in the front end to minimize weeping of thinner hydraulic oil in the hot weather
   / Has anyone used gear oil in front axle (instead of the hydraulic oil that the manufacturer recommends) AND had an issue? #4
My manual recommends either Kubota Super UDT or 80/90 gear oil. I use gear oil. 1500 hours no issue.
   / Has anyone used gear oil in front axle (instead of the hydraulic oil that the manufacturer recommends) AND had an issue? #5
Like this, it’s hot in the barn
   / Has anyone used gear oil in front axle (instead of the hydraulic oil that the manufacturer recommends) AND had an issue? #6
I worked at Kubota and used gear oil every time. Stayed in better.
   / Has anyone used gear oil in front axle (instead of the hydraulic oil that the manufacturer recommends) AND had an issue? #7
I used Super UDT 2 and developed problems when hot. The stuff pours like water! Switched to gear oil and the leaks became less noticeable.
   / Has anyone used gear oil in front axle (instead of the hydraulic oil that the manufacturer recommends) AND had an issue? #8
   / Has anyone used gear oil in front axle (instead of the hydraulic oil that the manufacturer recommends) AND had an issue? #9
Been using gear oil in the front end of my 35hp tractor for over a decade now. Like your tractor the manual says use either. So far no issues.
I also have hydraulic/trans fluid in the front end of my 23 hp tractor. So far I’ve had no issues with that one either. I opted to go this route on the small one because I had plenty on hand, and it seems to be good enough for the gears in the rear end. I am also conscious of what I have in there and probably over-cautious of not putting my front axle in any kind of overload or binding situation. I tend to use the larger tractor for the abusive stuff.
   / Has anyone used gear oil in front axle (instead of the hydraulic oil that the manufacturer recommends) AND had an issue? #10
I've used Mobil 1 75/90 synthetic in the front axel of my Kioti since new;2005 and no issues during Maine winters
2025 Future Stump Grinder Mini Skid Steer Attachment (A50322)
2025 Future Stump...
2015 International DuraStar 4300 Street Sweeper Truck (A50323)
2015 International...
Ih 1066 Tractor (A50514)
Ih 1066 Tractor...
2019 FORD F450 TOW TRUCK (A51222)
2019 FORD F450 TOW...
Wells Cargo Enclosed Trailer (A50324)
Wells Cargo...
2014 International Durastar 4300 Terex BT2047 47ft Crane Truck (A50323)
2014 International...
