Fed up with the garden
   / Fed up with the garden #101
Running really late on getting things in the ground, mostly owing to prepping the garden area.
Hauled a lot of screened compost down to amend the bed and then graded it.
Worked yesterday on getting weed block fabric (woven, which passes water) laid down, today getting some holes melted in it so we could get some of the pepper plants in the ground, many of which already have peppers on them.
Used a HF "weed burner" propane torch and a couple of stainless steel exhaust adapters to melt the holes:
Got 27 peppers in the ground today, probably another dozen or so to go. Eggplants will be next on the list after that.
   / Fed up with the garden #102
Yes if you have certain breeds, golden comets being one of them, the eggs will be bigger than what you get in the grocery store. I have seven golden comets. They are large egg laying machines
   / Fed up with the garden #103
I am fed up with my front garden. I have attenpted to start a few times, I get 70% complete then do nothing for a few months.
I find myself at a cross roads. I am either going to sell my house and as such I need to tidy up the front. Or stay where I am and redo the whole drive way, it is in need of some repair.
The area used to be grassed and I removed this a few years ago, put down some membrane, bark and some nice plants. However it is now in a state of repair.
The first thing that I need to do is clear the weeds and grass around the edges
A couple of challenges:
- I dont have any weeds growing through the membrane, but they do appear to grow in the bark. Is there anything I can do to prevent this.
- My drive is on a slope so the bark appears to move towards the path over time.
- Fence needs replacing.
- Edging needs replacing. In the first picture, you can see that there is a row of bricks between and the drive and garden area with extends 3-4" into the garden under the layer of the soil. This means that putting the edging in is difficult. I encountered a similar problem around the drain cover.
If I sell I need this to be an easy (due to my disability) and cost effective solution.
My preference would be to work with what I have, clear the weeds and put in a nice edge.
I would also like to do something under the front window, my ideas was a few biggish pots the same colour as my front door, and to paint the electric cabinets the same.
Pictures?
   / Fed up with the garden #104
Did someone say large egg? This came from a chicken. I was stunned and had I not collected it myself would have thought someone was yanking my chain. Those are grade A large brown eggs surrounding it. If you notice, the eggs around it are barely fitting in the egg carton themselves.
This was in late June. On the left is a typical egg around here (XL; some of my hens lay barely-large eggs but most are in the XL range). I pity the hen that dropped the double yolker
   / Fed up with the garden #105
That's a whopper. Now I'm curious and have to find the scales to weigh and measure mine
   / Fed up with the garden #106
Sometimes the obvious turns out to be the truth. I can't recall their names :unsure: but I heard a couple old men actually "planted" duck and turkey eggs in their neighbor's nests 😇. After people started questioning the man's creditability, the old farts drove 20 miles to buy fertile Naked Neck eggs to sneak under the man's brooding hen. In case anyone here missed the lesson,don't discuss it at the coffee shop when you plan to set some eggs and NEVER allow visitors to become friends with your dog. 🤣
   / Fed up with the garden #107
My goose (embden breed) lays very consistently sized 143-146g eggs
Here you can see 3 duck eggs in the back (73-76g), a bunch of chicken eggs (most in the 64-69g, one hen lays about 61 often, and someone very occasionally lays in the upper 50's), with the one-is-not-like-the-others goose egg:
Cooking with a goose egg is interesting - there's a fine line how much force does it take to crack it open vs splattering it!
I usually use the duck eggs to make pasta. IMO they're a bit strongly flavored for eating eggs straight.
   / Fed up with the garden #108
As long as your getting your tomatoes, beans, peppers, etc, I wouldn't be so concerned about edges. Clean it up with your tiller when the season is over. If it's too much to handle, reduce the size of your garden.
My mom is 89 and she won't quit her garden. It's only half the size it was but there are no weeds. If you're going to have a garden it has to be tended to weekly, if you can't do that, plant it to grass.
   / Fed up with the garden #109
My father raised geese and ducks for a few years. One spring we had a gathering and made ice cream from goose and duck eggs. It was a VERY rich recipe!! 😋
I sometimes get big eggs like that, usually from older hens. Often they are double yolks, but not always. Something else I once encountered; I would come home to find the nesting box all torn up and couldn't figure out what was going on. One night I found a dead hen on the box with an egg partially out, which is where it hardened. She must have had something wrong so that the eggs were hardening too soon.
   / Fed up with the garden #110
Where did you get that fabric? All I can find locally is more cloth-like and doesn't look like it would stand up to sunlight or foot traffic very well.
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2013 CHEVROLET SILVERADO EXT CAB TRUCK (A58375)
2013 CHEVROLET...
Unused 2025 CFG Industrial MH12R Mini Excavator (A59228)
Unused 2025 CFG...
UNUSED BIGFOOT AR500 3/8" STEEL SHOOTING TARGET (A58376)
UNUSED BIGFOOT...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58216)
SEMI AUTOMATIC...
