Recent Purchase. 555B Can someone explain how to tell the year from the serial number?
   / Recent Purchase. 555B Can someone explain how to tell the year from the serial number? #1
Joshua Shoemaker
Washington, Georgia
L3200 Kubota
This is my first backhoe. I'm in the process of building a house and so far all the prices I have attained for work is out of my budget. Which is typical for most of my life. So once again, I will spend the money on things I can't do myself or have the time to do. Since I have to dig footers, basement, powerlines, waterlines, and septic system. I got this. I believe this is a late 85 or an early 86. If someone needs more information, let me know. Any help would be appreciated.
   / Recent Purchase. 555B Can someone explain how to tell the year from the serial number? #2
Try this
   / Recent Purchase. 555B Can someone explain how to tell the year from the serial number? #4
Yeah I went there and it says to go to the steering wheels bearing and I have no idea what that means. There is no data tag in the cab. If there is supposed to be one, its not there.
Can you provide a better picture of the entire tag (shown on your first pic)? That is the “tag next to your steering wheel“ that has the info you are looking for.
You may need to do a pencil lead eching on a sheet of paper to be able to read all the info.
   / Recent Purchase. 555B Can someone explain how to tell the year from the serial number? #6
The serial number will start with the letter C followed by 6 digits. The date code will be number, letter, two numbers and letter.
What is pictured is a component plate for the backhoe or loader.
The model/serial number/date code plate is or was on the steering cowling LH side as you climbed on the tractor.
The other place to find these is on the RH top of the bell housing behind the starter stamped into the housing.
What Chewwy provided on deciphering the date is right on point
Okay,
There is nothing on the steering column. The only data tag is on the left side up near the top...see attached. I will have to see if I can retrieve it off the bell housing.
   / Recent Purchase. 555B Can someone explain how to tell the year from the serial number? #8
Okay,
That tag is the ROPS or cab tag. If it were present, it would look like the one pictured like the one on my 550.
Yeah, I don't have that there. Its blank, not even the lubrication chart. I have a rocker switch in the upper left corner by the windshield.
2016 Toro Reelmaster 4 Gang Mower Attachment (A55851)
2016 Toro...
2023 Kubota RTV-XG850 Sidekick (A55315)
2023 Kubota...
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
2012 Club Car Carryall 1 Utility Cart (A55851)
2012 Club Car...
2008 Ford Crown Victoria Sedan (A55853)
2008 Ford Crown...
UNUSED SDLANCH SDLC2020 - 20' X 20' CARPORT (A57193)
UNUSED SDLANCH...
