Kubota 1.8 VS 2.4
   / Kubota 1.8 VS 2.4 #1
JeepHead
The hills of Southern Indiana
Kubota 2502H, HSI Pinnacle grapple, LP 48" forks, LP 60" BB, KK tiller 60", KK middle buster, Pat's QH
Are both of these engines equally as good or does one have a better history than the other? Considering
   / Kubota 1.8 VS 2.4 #2
Dont really know of any bad kubota engines. But those are basically the same engines. Same bore/stroke. The 2.4 just adds an extra cylinder. But its all dependent on application. And which variation of the 1.8L and 2.4L.
But if you are that concerned about the engine.....try to go with the largest displacement for a given HP. The 2.4 is in 40hp tractors on the small end up to about 50HP. Then they throw a turbo on and push it up to 60hp.
So if you are looking for a 40HP engine.....The 1.8 is about maxed out. And the 2.4L is obviously barley breaking a sweat if it can handle 50% more power and a turbo.
I assume maybe you are looking at a 3560 vs a 4060?? If thats the case....dont get hung up on the engine. They are both good in the GL platform. But the 4060 is physically a larger tractor. Bigger tires, a little longer, few hundred pounds heavier. The 4 cylinder will run a little smoother naturally
  • Good Post
Reactions: JWR
   / Kubota 1.8 VS 2.4
Very useful information and insight. I appreciate your time and response.
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51691)
2009 Hino 268...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A55314)
2023 Kubota...
CATERPILLAR CP44 PADFOOT ROLLER (A52707)
CATERPILLAR CP44...
40ft Sea Container (A52384)
40ft Sea Container...
