UTV tire pressure?
/ UTV tire pressure? #1
dj1701
East Concord, NY
John Deere 4320, Kubota BX2680
Question?
I have noticed the rear of my Kawasaki Pro-Mx tends to squat more than the front. The rear tires are flatter than the fronts with the same air pressure. I realize that that most of the weight is in the back which would cause this.
I have adjusted the shocks, but could I run a higher tire pressure in the back, or would that be unwise? Would not the flatter tires cause a diameter issue in 4x4?
Thanks
Dave
/ UTV tire pressure? #2
You don't say what pressure you have in the tires, but if you increase the pressure above the recommended pressure you will likely create a crested or domed configuration which will lead to accelerated tire wear. I run my tires at 9lbs on my Polaris Ranger; find that works for me. Were I to load the dump body heavily, I would increase the rear tire pressure
/ UTV tire pressure? #3
I run the tire pressure on our side by side at the recommended sidewall pressure unless I'm in adverse conditions like mud or sand and then I'll lower the pressure accordingly. I do the same deal with my 4x4 pickup truck.
I'm running 10psi all around. The Mule Pro-Mx sits low in the back without any added weight. I have adjusted the preload in the back as much as possible to even it out. I will try adding some air, 18psi is max.
Thanks
Dave
/ UTV tire pressure? #5
I would not be adjusting tire pressure for the reason of making the stance of the UTV to look different.
/ UTV tire pressure? #6
Can you adjust the preload in the front?
It doesn't look too bad, but the rear tires squat much more than the fronts. Just wondering if others use different psi front to rear.
/ UTV tire pressure? #8
Are they the original tires? Correct ply rating? Maybe the rears are just a flatter profile?
They are all 8-ply radial 28x10x14 Maxxis Carnivores.
/ UTV tire pressure? #10
From what I could find, the original f/r tires were different sizes and the rears were a bit wider than the fronts. The wider rears would offer more load carrying capacity than the narrower fronts. If you changed to tires that are all the same size, I can understand why the rears squat a little more.
/ UTV tire pressure? #11
10 psi in all tires on my Can-am Defender...27x9x14 front tires and 27x11x14 rears.
/ UTV tire pressure? #12
I run my Warrior 800 at 12 PSI,
I almost never run any of my tires at the tires max pressure, that pressure is for when the tire is loaded to it's maximum capacity.
/ UTV tire pressure? #13
Depending on your tire and application. Adjust the tire pressure as needed
I normally on V treads would run 5-7 psi rear and 7-10 front. Mostly off road
/ UTV tire pressure? #15
Do keep in mind that low tire pressure can result in the tire spinning on the rim and totally deflating.
On our side by side I run sidewall pressure because it gets roaded a lot and it's capable of 50 mph plus.
/ UTV tire pressure? #17
Polaris ranger 500 I run 10 lbs. all around
/ UTV tire pressure? #18
In general, The tire sidewall pressure is the maximum rated PSI for that particular tire. Not for the vehicle its mounted on. For most vehicles, tractors, etc. the manufacture sets the recommended pressure for that specific machine and tire combo. Check the drivers door jamb or owners manual for proper recommendations.
A car or pickup with 44# is one jittery ride and poor performing tire & handling.
2020 Ford Explorer AWD SUV (A64557)
2020 Ford Explorer...
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
2011 FORD F-350 FLATBED DUMP TRUCK (A64278)
2011 FORD F-350...
2011 International DuraStar 4400 18ft. Cab and Chassis Truck (A64194)
2011 International...
2012 CLUBCAR GAS GOLF CART (A65054)
2012 CLUBCAR GAS...
Jobox Truck Bed Tool Box (A64556)
Jobox Truck Bed...
