How to get a pasture to bare dirt?
   / How to get a pasture to bare dirt? #1
whitravis
3215 Mahendra
I have an acre of field grass. Its also lumpy and bumpy. I want to get rid of the grass and smooth the field with a box scraper. Kill the grass, run a disc over the field, then the scraper box, or??
Or kill the grass then turn it under with a two bottom plow?
33HP
   / How to get a pasture to bare dirt? #2
A lot of farmers would just turn it with a one bottom plow. Let it sit for the grass to die a bit and then disc it. I have reservations that 33hp will handle a two bottom plow.
   / How to get a pasture to bare dirt? #9
First step is to spray it with glyphosate or something similar and kill what's green. For only an acre, I get better results with a tiller and then a drag rather than trying to disc it. Plowing it just makes it much rougher and you need even more aggressive equipment to get it smoothed back out.
YMMV
   / How to get a pasture to bare dirt? #10
An acre, I would just mow it short and run a tiller over it a few times. I've done that on my place with good results. Some around me don't have a tiller and just use a disc. That takes a lot longer, especially in the dry. Discs don't cut very well through roots.
SALTYS MANFUFACTURING 500BBL FRAC TANK (A58214)
SALTYS...
2011 Nissan Rogue SUV (A56859)
2011 Nissan Rogue...
SDLD25 MINI DUMPER (A58214)
SDLD25 MINI DUMPER...
DIRT DOG BBX48 48" BOX BLADE (A58375)
DIRT DOG BBX48 48"...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
Hydraulic Dingo Concrete Mixer (A55272)
Hydraulic Dingo...
