How to get a pasture to bare dirt?
   / How to get a pasture to bare dirt? #1
whitravis
3215 Mahendra
I have an acre of field grass. Its also lumpy and bumpy. I want to get rid of the grass and smooth the field with a box scraper. Kill the grass, run a disc over the field, then the scraper box, or??
Or kill the grass then turn it under with a two bottom plow?
33HP
   / How to get a pasture to bare dirt? #2
A lot of farmers would just turn it with a one bottom plow. Let it sit for the grass to die a bit and then disc it. I have reservations that 33hp will handle a two bottom plow.
   / How to get a pasture to bare dirt? #9
First step is to spray it with glyphosate or something similar and kill what's green. For only an acre, I get better results with a tiller and then a drag rather than trying to disc it. Plowing it just makes it much rougher and you need even more aggressive equipment to get it smoothed back out.
YMMV
   / How to get a pasture to bare dirt? #10
An acre, I would just mow it short and run a tiller over it a few times. I've done that on my place with good results. Some around me don't have a tiller and just use a disc. That takes a lot longer, especially in the dry. Discs don't cut very well through roots.
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2006 Hackney T/A Hazmat Truck (A56858)
2006 Hackney T/A...
2004 VE ENTERPRISES 500BBL FRAC TANK (A58214)
2004 VE...
Quick Coupler Plate Loader Attachment (A56857)
Quick Coupler...
1619 (A58375)
1619 (A58375)
10' CONTAINER (A52706)
