   / Harbor Freight Tools that don't suck #15,431
For some reason that word in the description causes HF's ad software to show it as a closeout. It isn't. It's been shown as 'clearance, closeout' for some 15 years now.
That's about when I got my QH from them. I think I paid less than $80 back then. It's still in use. (y)
   / Harbor Freight Tools that don't suck #15,432
"Clearance" doesn't mean what it says. It just a description of the measurement between lower hooks.
So the 20% coupon doesn't conflict with any discount.
And - Maverick you did good. HF's QH is my most-used HF purchase ever. Recommended!
I noticed they had a top link there too. It's on my list to snag next time around. It's good to have a spare or two.
   / Harbor Freight Tools that don't suck #15,434
I bought HF's Top Link and found it is too long for everything on my Yanmars except tipping the box blade back extremely (for smooth grading).
Check this before buying!
re the HF Quick Hitch:
From your Yanmar-thread post: So a HF store manager said they really are closing out the Quick Hitch after all these years? I bought one of the first ones and it still works like new. Recommended. Everybody, jump on this if you need one, the quality is same as all the store brands that sell at 3x the price.
But also buy the replacement top hook with offset holes so the hook extends our farther from the hitch chassis, if needed for clearance on your implements.
Some stock photos from a search on Amazon for 'quick hitch top hook'. I use clips like the second photo, for quick adjustments.
   / Harbor Freight Tools that don't suck #15,435
re Quick Hitch Clearance / Closeout:
I just did HF's 'Check Other Stores'.
Every store in a 200 mile radius from the San Francisco Bay Area - Arcata to Reno to Fresno, 50 stores and including California's Central Valley which is a huge ag area, reports they have the QH in stock. Only one of the 50 shows Limited Stock.
Maybe the closeout is regional???
Some QH links:
Post on here showing Speeco's upgrade Top Hook with the offset holes for more clearance.
HF magnet tool bar, cut down and welded on the QH so clips and linch pins don't fall down in the weeds when adjusting the top hook.
Tow bar modified so the trailer ball stays upright. Both ends of the strap are bolted to existing holes.
Temporary rear ballast, when backfilling a trench in a very tight space between barn and fence. I should have also had that towbar on, to get the weight a little farther back and reduce swinging.
Edit: links to photos corrected.
   / Harbor Freight Tools that don't suck #15,436
Some QH links:
QH shows in stock in Ma and NH stores.....
   / Harbor Freight Tools that don't suck #15,438
Why does every Harbor Freight store have the exact same smell? And what is it?
Caterpillar 906M (A53317)
Caterpillar 906M...
2021 Caterpillar 308 Midi Excavator (A55973)
2021 Caterpillar...
2015 Chevy Cruze Sedan (A56859)
2015 Chevy Cruze...
2020 Caterpillar 259D3 Compact Track Loader Skid Steer (A55973)
2020 Caterpillar...
CAT 777B ARTICULATED DUMP TRUCK (A58214)
CAT 777B...
2002 Bobcat 763 Compact Skid Steer (A56435)
2002 Bobcat 763...
