Additional garage lighting......thoughts?
   / Additional garage lighting......thoughts? #1
Richard
Super Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
The light fixture in the garage is of course.....in the center of the garage.
Just yesterday, we assembled some mega shelving that the wife bought and of course, she wants it in the middle of the garage (which is more of a storage room for stuff rather than auto's)
This thing essentially blocks all of the direct radiating light to the rest of the room making the whole place darker.
I'm looking at ideas. First is add some shop lights and run them down the 'isles' between this shelving and the room.... they'd hang below the ceiling rafters so I got to thinking, there might be something more suited to fit BETWEEN the rafters that I could still let hang down 1-3 inches which would still tuck it away better than a hanging shop light.
I'd probably need 4 minimum of them to do what I want (verses probably two 4' shop lights although I was thinking on doubling them so each side would have 8' of lighting)
So far, can't find anything that rings my bell.....thought I'd reach out here for wider comments.
Don't expect this to matter much but, this is all switched at the wall.
   / Additional garage lighting......thoughts? #3
The cheap disposable LED lights are low current and can daisy chain. I've used a bunch of the cheapest ones on Amazon and they have lasted for years so far. I've used self contained 4' lights and modified some florescent fixtures to use LED tubes. Not pretty but functional and easy to install and replace if needed.
   / Additional garage lighting......thoughts? #4
The LED lights are the way to go. I've had pretty good luck with the Barrina V-Shaped shop lights from Amazon. I tried a few from Harbor Freight when they were on sale and they were badly made and failed quickly.
   / Additional garage lighting......thoughts? #5
Long lasting quality high output LED 4 ft fixtures are worth extra the cost, They come with hangars but i have I screwed these directly to the ceiling too.
   / Additional garage lighting......thoughts? #6
It would not be that hard to add wooden sections between the rafters and spacing them to give the height you are seeking. Then mount the fixtures to the spacers parralel to the rafters.
   / Additional garage lighting......thoughts? #7
I put up 10 or so 4' LED lights in my 750sq ft garage. They're running off the existing 15a light circuit with plenty of amps to spare.
Some are LED replacements for flourescent tubes and some were new fixtures made for LED tubes. I got the fixtures from Costco. The ones I got can be daisy chained, which is common and makes wiring them up easier.
   / Additional garage lighting......thoughts? #8
I used some LED troffer panels (drop ceiling) from Home Depot, but they are easily suspended. Lots of light and very low cost to run.
https://www.homedepot.com/p/2-ft-x-...eiling-Light-4-Pieces-panel-4pack-B/321758847
All the best,
Peter
   / Additional garage lighting......thoughts? #10
Sounds like the bigger issue here is 'girl creep' into the garage !
Time to use it to your advantage to build a pole barn !
Brilliant !
I use 4' led tubes. Painting ceilings,rafters and walls white helps regardless of type lighting.
Utility Trailer (A52377)
Utility Trailer...
2016 Ford F-150 Pickup Truck (A54814)
2016 Ford F-150...
2017 Ford Explorer AWD SUV (A55758)
2017 Ford Explorer...
Informational Lot - Shipping (A55302)
Informational Lot...
9202 (A50322)
9202 (A50322)
2025 Kivel Fork and Frame Mini Skid Steer Attachment (A53421)
2025 Kivel Fork...
