Kubota B2910 Not Starting with Ignition Key
   / Kubota B2910 Not Starting with Ignition Key
Fuse was burnt out on the one for the dash fuse. Put a new one in and the panel works now.
I haven't torn the tractor apart yet, but how would one tell if a safety switch is not working properly. I am able to reach 2 of them, and compressing the button. I assume there should be a click, but both don't really make an audible noise.
tl;dr - How do I check if the safety switches work?
   / Kubota B2910 Not Starting with Ignition Key #12
Jumper wire BTW the 2 contacts.
   / Kubota B2910 Not Starting with Ignition Key #13
Did you definitely eliminate the switch at the clutch pedal as NOT being your problem? I had that one work loose on mine once and had to simply pull it back into the housing and tighten the retaining nut so the clutch pedal would depress it adequately. It's right out there where you can see it and just can't tell that the plunger doesn't quite close the switch.
On most any of these switches, you can just disconnect them and take a bent piece of wire to jump across the terminals to see if that resolves the problem.
If not the clutch, there are 2 PTO switches (rear and mid-PTO levers).
My seat switch has been disconnected since I got it, so not sure if that has to be "closed" in order for it to start or not, but it's super easy to jump across that one in order to check it too.
A year and a half later, and I finally got it fixed! The first time I tried to fix was before winter in 2022, and I only tested the 2 safety switches under the seat (PTO, and Neutral safety switches). I did this by switching them out with a new safety switch I picked up at the Kubota dealership, and there was no fix.
This weekend I finally did a teardown, and it ended up being the clutch switch, that was not pressed in deep enough, when the clutch was pressed. The original safety switch was functioning properly after adjusting it down.
A few notes:
3 Safety Switches (at least the 5T057-42230 part #):
PTO, Neutral, and Clutch
All 3 safety switches, must be compressed to start with key.
The instrument panel, dash plastic, steering wheel, and hood are very difficult to remove without a manual. Kubota really screwed the pooch on this. Lot's of yanking, and wiggling that should be much easier on a tractor. I get why they do it on cars to make them look pretty, but there were many bolts that required universal socket joints.
I will concede to Kubota that all the bolts had the nuts welded to the metal, which eased my mind on losing them.
The clutch safety switch can be seen from the bottom the tractor, but it is much easier to remove, and adjust by removing the hood and orange metal (they're connected together). I really should have recorded for you all, because there were no tutorials on YouTube, but hopefully it will be quite sometime before I have to dig into the tractor again.
AND FINALLY make sure to connect all the starter wiring back properly after you've been starting with a remote switch for a 1.5 years. I forgot to connect the little solenoid wire, and that probably wasted an hour or so.
Battery light is still on while operating???
Good luck out there y'all, and Thank you for the help on this thread.
Safety Switch part on Amazon.com with part numbers (5T057-42230) etc.:
Just something to keep in mind.
I have a B2910 also. I have read that some of the later models have different wiring than my workshop manual shows, and include an OPC module (Operator Presence Controller).
A give away is if the B2910 has a seat switch or switches. I think this holds true for the B7800 as well, but not sure. My b2910 does not have the OPC or switches under the seat.
Mine did not appear to have any OPC safety switches, or "modifications" to remove said switches.
   / Kubota B2910 Not Starting with Ignition Key #16
Well, at least you found it. As mentioned above, this was exactly the same problem that I had with mine. The clutch was depressing the switch button but not quite enough to close the circuit. Just needed adjustment.
Did you say that your BATTERY light is now on all the time when it's running? When mine did that, the voltage regulator was fried. In fact, it got hot and started smoking while I was using it. I wonder if you've shorted it out while swapping wiring around.
I bought a cheap one off of Amazon and installed it. It worked but got hot and went up in smoke within a couple days. Then I bought the official KUBOTA part and replaced it and it's been fine for a few years now. (The cheap knockoff looked IDENTICAL right down to the markings in the heat-sink casting metal.)
You got a link to that part? or copy paste the exact name on amazon?
   / Kubota B2910 Not Starting with Ignition Key #18
Kubota B2910HSD (Hydrostatic Transmission, 4wd) Parts Diagrams
It’s the “regulator”. Pretty easy install. Goes behind the dash panel. There are diagnostics recommended but I never could get a definite result. In my case it got hot and smoked and nearly caught fire.
I just pulled this up quick. Verify that this fits your serial number etc. in case there’s a serial number break.
I’d suggest getting the kubota part. I wasted time and money with the cheaper part. It looked identical but it also started smoking after a couple days.
Good luck.
   / Kubota B2910 Not Starting with Ignition Key #19
It’s the “regulator”. Pretty easy install. Goes behind the dash panel. There are diagnostics recommended but I never could get a definite result. In my case it got hot and smoked and neatly caught fire.
Good luck.
I thought that link would take you to the exact page. Look under “electrical” and then under “switch”. There are two pages and both show the “regulator”.
   / Kubota B2910 Not Starting with Ignition Key #20
I would probably start with the neutral safety switch as lots of issues are reported going bad and shifting to be out of alignment.
John Deere 1100 3 pt Field Cultivator (A50514)
John Deere 1100 3...
F-500 POWER PUMP 500HP TRIPLEX POWERED BY 3412 CATERPILLAR ENGINE (A50854)
F-500 POWER PUMP...
2019 CATERPILLAR 930M WHEEL LOADER (A51242)
2019 CATERPILLAR...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A49461)
2014 MultiQuip...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A49461)
2016 Ford F-450...
2021 CATERPILLAR 299D3 XE SKID STEER (A51242)
2021 CATERPILLAR...
