NX55 HST Jerky Transmission at Low Speed
   / NX55 HST Jerky Transmission at Low Speed
I contacted Kioti and provided my tractor info and requested that my tractor get the upgrade. Should hear back soon.
I also measured my hydraulic fluid temperature after running the PTO for a few hours and to the point where the hydraulic system started to get jerky or pulsing. It read 215F which is 19F higher than the upper limit on the hydraulic pump spec @ 194F.
Well, that was quick. Kioti replied and said my tractor was not eligible for the mandatory upgrade and I should bring the tractor to my local dealer to look at the jerky hydraulics issue.
   / NX55 HST Jerky Transmission at Low Speed #53
Clipped about 7 acres of pasture pulling an 8’ twin spindle pull behind bush hog today at 540 pto rpm the whole time. 95 degrees heat index of 104. Suction line on using my laser Klein thermometer read nearly 210 degrees. No jerkiness whatsoever.
Good info, thanks!
Which hydraulic fluid do you use?
   / NX55 HST Jerky Transmission at Low Speed #55
Kubota super UDT2
2012 EZ-GO Cart (A55853)
2012 EZ-GO Cart...
2022 CHEVROLET SILVERADO 1500 (A55745)
2022 CHEVROLET...
2018 Autocar ACX Xpeditor Garbage Truck (A55852)
2018 Autocar ACX...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A56138)
2019 INTERNATIONAL...
2018 Chevrolet Silverado 3500HD 4x4 Crew Cab 9FT Flatbed Truck (A51692)
2018 Chevrolet...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2019 FREIGHTLINER...
