YANMAR YM2200 fan belt.
   / YANMAR YM2200 fan belt. #1
RobertYanmar
Orange Park, FL
Yanmar YM2200
I am trying to replace my fan belt.
The Yanmar part number seems to be 12451-42290, but I don't have the specifications.
I wonder what would be an equivalent belt in a more available brand.
Any suggestions would be most appreciated. Else I will take the belt off and carry it to local shops.
Thanks
Robert
I found it at Hoye tractor, just as I previously found other parts I needed.
   / YANMAR YM2200 fan belt. #3
If you want to know the size use a piece of rope mark it
measure it and then measure the belt you should have a
good idea of the size needed
willy
Than you Willy.
I got the replacement belt.
When I was installing it, I realized why the belt frayed; the tensioning bar was loose, having lost the bolt that attaches it to the block. The threaded hole in the block appears intact, so I suspect the bolt came loose and fell out. I am trying to purchase a replacement bolt, but I cannot tell the size and whether it is metric or not. My Japanese parts manual does not show a number for this bolt. Does anyone have an idea?
It is wider than the bolt that attaches the other end of the "tensioning-bar" to alternator, but I cannot tell its size.
Thanks
Robert
Than you Willy.
I figured out the bolt ! It is a M8 1.25 65mm long metric bolt with about 2cm of the tip having thread, the rest smooth.
   / YANMAR YM2200 fan belt. #7
So it's an M8 shoulder bolt. nice.
What type of belt did you get? Was it a kevlar type. V-Belt Supply has them in kevlar. It will outlast the machine.
BTW, it you ever need the manuals in PDF to just do the snip tool and post here, we have them at the YTOG,
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2017 Chevrolet...
2017 DITCH WITCH RT30 RIDE-ON TRENCHER (A51242)
2017 DITCH WITCH...
Komatsu D39PX-24 Crawler Tractor Dozer (A49346)
Komatsu D39PX-24...
2025 LandHonor LHR-DFP10 Diesel Fuel Transfer Pump with Hose Reel (A49461)
2025 LandHonor...
2015 MACK GU713 (A50854)
2015 MACK GU713...
2014 New Holland T8.360 MFWD Tractor (A51039)
2014 New Holland...
