Clearing 154 acres of woods in west Tennessee
   / Clearing 154 acres of woods in west Tennessee #31
Get topo map of the property Topographic Maps | U.S. Geological Survey to start to layout fields and low areas - and a water source/pond stream for cattle. You will need about 1.5-2 acres per head on grass and you need to rotate them through fields.
You have to check with the local authorities first. Some places require livestock to be fenced out of streams and ponds, especially if you go looking for grants/loans to help with the bills.
   / Clearing 154 acres of woods in west Tennessee #32
I would do some research(talk to a local older farmer?) on why the forested part wasn't cleared years ago, or kept clear if it once was cleared?
I do see people here nibbling away at woodlands to extend fields, but then I also see the big equipment rutting up soft ground as usually its quite wet... Usually there's a reason no one in the previous 100-200 years didn't farm it? What I'm seeing in general here is farmers concentrating on improving their better acreage and marginal farmland is being cut up and sold.
Also I don't see many people pasturing beef anymore, but that may be a local thing, up here with a shorter growing season its more cost effective to run land as hay fields than pasture as you need hay for 5 months of the year in any case...
Maybe try clearing a smaller chunk and see how it goes, or get your woodland professionally evaluated? The woodland may provide a smaller, but with a fraction of the labor and investment, source of income forever, if managed properly?
^good advice here. Soil type, topography, hydrology, hidden dumps, etc... could all come into play on a piece that large. And getting paid for the trees being removed can't be a bad option to explore.
   / Clearing 154 acres of woods in west Tennessee #33
Unless it's planted pines, I don't think there will be much value in timber. Hardwoods are typically worthless unless maybe you have nice straight walnut, then, a custom forester would be well worth it.
Edit: I need to qualify that statement; in my area of N Fla, oaks are the normal hardwood, and are worthless trash trees.
   / Clearing 154 acres of woods in west Tennessee #34
Yes, the county Ag Extension Agent can be a great source of info and help, but this is a working farm now, and just suggesting the OP get his plan together with maps and local regs. before bringing/inviting any govt agency on site.
Livestock need water, and this is an existing 300 acre farm so doubt that applies.
   / Clearing 154 acres of woods in west Tennessee #35
I'd consult a forester. I see a lot of hardwood, white oak maybe, around west Tennessee going for staves, pallets and, maybe, ties. When we cut timber in north Mississippi, hardwood pulp was higher than pine pulp. I think it's highly location dependent.
   / Clearing 154 acres of woods in west Tennessee #36
In Md., you would be 100% wrong. Ponds are to contain water, you’re supposed to pipe it out to watering troughs, etc for use. The natural resources conservation is coming out Tuesday to check our pond fences and take pictures of it.
The USDA guidelines under water quality suggest fencing out livestock, Md is saying you will do it. Hence the suggestion to check before you start.
   / Clearing 154 acres of woods in west Tennessee #37
Locally, they’re still working on a 200 acre clearcut for a new solar farm. That project swamped the local mills and pulpwood is @ 10/ton. The mills are now selling oak @ 1.00 bf retail. Poplar is .75 bf.
   / Clearing 154 acres of woods in west Tennessee #38
do wish you the best on your project, & some good ideas voiced here. to be honest, i don't envy you the job, or what you'll end up with. have you calculated how many yrs row cropping it will take to retrieve your investment which ever method of clearing that you use?
sounds like a lot of work. add the nature of droughts, flooding, & extreme heat & polar vortex sounds like an uphill battle. what really will you be left with on your place at the end of the day? you already have a lot of cleared land, why not just develop that?
but all the best on your endeavor, keep the thread going with your progress
best regards,
   / Clearing 154 acres of woods in west Tennessee #39
Do you think most farmland is just magically devoid of trees and it was found that way? OP did not ask for your opinion about whether or not it should be done. If you cared so much you would be out volunteering to plant a few hundred trees a week. But I doubt you are. I planted 280 on my property a month ago....lots of work!
What I think (wait, are you asking my opinion? lol) is that we have plenty of cleared farmland already in this country, and what we need, is more forest and natural habitat, not less. There are thousands of acres of fallow farmland just around my own county here in Michigan. I'm sure there are in TN also.
Not to mention that 87% of our farmland is used for poor-rotation monocrops just to feed livestock. No, I'm not anything close to a vegetarian, but our food system is certainly pretty F%^&d up.
I stated clearly in my first reply that it was not my place to judge the ethical implications of carrying out this sort of idea, but as many others have astutely pointed out, it will also probably be terribly expensive and difficult, and perhaps not even result in achieving the stated goals.
   / Clearing 154 acres of woods in west Tennessee #40
Kinda off topic just a bit; but be careful basing financial decisions on short-term commodity prices. Something might make a lot of sense when prices are high, but if you're still paying on a loan 5 years from now, and corn is $4/bushel; that might not be good. No saying bottom will fall out, just saying don't forecast $9 corn to make things work. Forget who said it recently, but "never under estimate the ability of American farmers to over produce and tank record prices in just 24 months".
2014 GMC Terrain SUV (A56859)
2014 GMC Terrain...
Hays LT1 Tender (A56435)
Hays LT1 Tender...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Altec AT41M Boom (A55302)
2016 RAM 5500...
SAKAI SV544D SMOOTH DRUM ROLLER (A52709)
SAKAI SV544D...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
12V 20GPM Gasoline Fuel Transfer Pump (New/Unused) (A59225)
12V 20GPM Gasoline...
