The one thing that you wonder why you didn't buy sooner?
/ The one thing that you wonder why you didn't buy sooner? #21
FEL on my tractor has been a life changing event!
Honorable mentions:
Power miter saw
MIG welder
Porta Band Saw
/ The one thing that you wonder why you didn't buy sooner? #22
A grown up excavator.
If you have the property or needs that warrants it.
/ The one thing that you wonder why you didn't buy sooner? #25
But try a 50/50 mix of ATF and acetone. That actually works." TMK. Yes! This is something I learned HERE from TBN. :)
/ The one thing that you wonder why you didn't buy sooner? #26
Forklift. I have a smallish 5k 3stage CAT forklift. Won't ever be without one.
Bobcat Skid Steer. Best dam wheelbarrow ever... this year we put a big old brush hog on the front of it.
It did a job of the 5 ft tall stuff. Best of all when you cutting in front of the tires.
/ The one thing that you wonder why you didn't buy sooner? #28
Wow, great thread!
My list is very similar to others...Mini Excavator, tractor with FEL, 18v grease gun, 18v air compressor.
Oscillating saw, pocket folding utility knife, four way screwdriver with the bits that flip around, Construction Master Pro calculator, Grip6 belt...
/ The one thing that you wonder why you didn't buy sooner? #29
A loader tractor WITH power steering. Now they all have it. There's a reason for that.
But there were decades where they didn't. You could spot heavy equipment operators by the shape of their arms.
Second place goes to battery-powered tools of all kinds.
Third would definitely be the thumb on our backhoe.
Fourth is yet to come, but I'm sure noticing that the 4 post lift got mentioned so often.
BTW, how many lifts are outside? I don't have an inside space for that.
/ The one thing that you wonder why you didn't buy sooner? #30
For years, the way I did things was to find a way. That was partly out of necessity (lack of money), and partly out of philosophy (being poor doesn't mean living poorly). I have a lot of things, and there are those that I wish I'd gotten (or made) sooner, but I didn't buy them. But to your point - my battery Milwaukee drill goes where I go, extreemly useful, should have been done sooner.
/ The one thing that you wonder why you didn't buy sooner? #31
That small crane I mentioned earlier has a 3-stage Cascade forklift in the front (Unimog HMMH). With 4WD and lockers it is quite useful. But I use pallet forks on the tractors far more often.
Mine is a cheap one, and not supposed to be outside, but after covering the motor and fluid container to keep water and UV from destroying them, it works great after about 10 years.
I do spray a little lube on things every two years or so. But it's not all that useful during the winter when covered with two feet of snow. Of course, it's black so if I want to use it just shovel some of the snow off of the runners and the sun does the rest.
/ The one thing that you wonder why you didn't buy sooner? #33
A reciprocating saw ("sawzall"). I use it so often that I truly wonder why I "didn't buy sooner".
Seeing as I'm 'dedicated' to Makita, that's the one that I purchased. A heavy (weight-wise) one IOT let the tool do the work.
/ The one thing that you wonder why you didn't buy sooner? #35
Wow, great thread!
Oh, yes, I forgot about my cordless air compressor. My wife also loves it and airs up her own car tires, and helped me air up all of the tires in the barn this year. I wouldn't be without one now.
/ The one thing that you wonder why you didn't buy sooner? #36
QA loader option + Loader forks. I use them more than a bucket now.
Yep, forgot to list the forks on my list. Can't imagine life without them! Thinking about getting another set for the skid steer...
/ The one thing that you wonder why you didn't buy sooner? #38
Man, I have so many things that I consider absolutely essential now. But I’m going to say three things I wish I would have gotten sooner than I did…because I can.
Good pressure washer
Welder
Good air compressor
Told my daughter the other day my wedding gift will probably be a air compressor if her husband doesn’t have one.
