CT1021, right rear wheel broke off from differential.
   / CT1021, right rear wheel broke off from differential. #1
GAIJR
CT1021
CT1021, 17 hours on machine, right rear tire assembly disconnected from differential, all fluid loss! In essence rear tires are falling off.:(
   / CT1021, right rear wheel broke off from differential. #2
Assuming it's a new machine, the dealer has some explaining to do.
   / CT1021, right rear wheel broke off from differential. #3
Don't touch it. That's a warranty claim; that's a 'they can pick this up on their dime' warranty claim.
Absolutely unacceptable.
The Bobcat dealer, has picked up the tractor, with no hydraulic fluid, it was winched onto a flatbed, with some difficulty. When the shop, lets me know exactly what they find that caused the wheel to separate, I will post the cause.
There is a "retainer clip" on the rear wheel, Bobcat tells me this clip let go, it was not broken, possibly not installed correctly at the factory. The dealer fixed the problem along with picking it up and delivered back at no charge on the warranty problem.
New Wolverine Sid Steer 3PT Hitch Quick Connect (A59000)
New Wolverine Sid...
(2) HOT FUDGE DISPENSERS (A58374)
(2) HOT FUDGE...
LOT: (10) Wheel Loader Bucket Teeth (A59076)
LOT: (10) Wheel...
Front End Loader Fork Attachment 20,000 lbs 5 foot (A59213)
Front End Loader...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A55973)
2019 Freightliner...
2020 DRAGON ESP...
