Branson 5520r issues electrical
/ Branson 5520r issues electrical #1
branson 5520r
Branson
Last week l want use my tractor turn the keys he start about 5 to 8 time.
So l turn the keys of and tey again but this time no light in the dash and hebdont want start.
I check the battery 12.7,the starter same thing.
So whats the probleme.
Thanks
/ Branson 5520r issues electrical #2
Not enough information to know the problem. But here are some possible issues.
1. Battery. It should be load tested.
2. Bad ground. Check connections at the battery and engine.
3. Fusible link. Check power down stream.
4. Blown fuse in fuse box. Check all fuses are good.
5. No power to fuse panel. Check for bad connections or broke wire.
6. Key switch. Check voltage in and out of the switch.
7. Faulty battery leads. Do a voltage drop test to make sure the leads can carry the load.
8. Safety circuit. One of the safety switches have failed or not made.
9. Bad Connector. Check all the connections in the wiring harness to make sure they are good.
10. Bad or Broke wire. Perform wiggle test on harness to see if power returns.
You may also want to download the service manual and look at the wiring diagram. Hope this helps some. Good luck.
My battery test 12.7,my starter 12.7 and the alternator 12.7.
But l cant tell you if the alternator pull too much juice the tractor dont want start (no tic tic nothing **** all.
The first time he make the motion to try start good maby 5 to 8 time and no more electrical its like if l disconneced the positif one shoot.
And said ok l turn the key off and l turn at the first click for see the go plugs and all the rest off the light in the dash but light come on **** all.
So the first think l do its put the battery at low charge for 2-3 hours give a break for 2 hours and give him a charge for 2 hours around.
After that l check with my multimeter my battery 12.7 thats is good.
So l check all the small fuses all good and l blow whit they air and take out the square relay in the top and blow they air to.
I take the swich out and blow air to.
I gone try to send you a pic of the fuses box and the relay but the relay l dont no how to check if is good or not.
/ Branson 5520r issues electrical #4
Start with checking voltage on the fuses in the fuse box. A pin light is helpful for tracing electrical issues.
Verify voltage on both sides of each fuse. Some of them will require the key to be in the on position.
Ok thanks l check those things
2009 Chevrolet Silverado 2500 Crew Cab Pickup Truck (A61568)
2009 Chevrolet...
2025 GPS Trailers (A56857)
2025 GPS Trailers...
2012 UTILITY REEFER TRAILER (A58018)
2012 UTILITY...
2019 Freightliner M2 106 Altec AA55 55ft. Bucket Truck (A60352)
2019 Freightliner...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A60352)
2006 Ford F-750...
