FORD F 1700 REMOVING HYDRAULIC FILL PLUG
/ FORD F 1700 REMOVING HYDRAULIC FILL PLUG #1
Justadudewithatractor
1979 Ford 1700
Hi all.
Don't know if the hydraulic fluid has ever been changed. It must have at one point, but it hasn't been changed in at least a decade.
Trying to get the fill plug unscrewed and it's not happening. I used Kroil on it and it still won't budge.
Any and all suggestions are welcome.
Thanks for your time!
/ FORD F 1700 REMOVING HYDRAULIC FILL PLUG #2
I would start with a block of wood and hammer. Try to catch the broken part on the right side of your picture low close to the threads. Hold the wood there then hit the end of the wood with a hammer. If that did not work I would move to an old socket extension and try to drive it out with that. If that did not do it I would go to a chisel and get a replacement cap. The chisel will cut it all to pieces.
/ FORD F 1700 REMOVING HYDRAULIC FILL PLUG #5
Those are very brittle, and when you break them, not easy to locate. (so far, but haven't looked really close). I put an adjustable freeze plug in mine in order to keep water and dust out till I found one.
A Cresent Wrench isn't the way to go...
David from jax
/ FORD F 1700 REMOVING HYDRAULIC FILL PLUG #6
You may can put a radiator hose clamp around it real tight. Bump the knot where the screw is in the clamp. Since it is a little chewed around edge, clamp will hold. If you salvage it, get an aluminum or steel replacement made. Rubber freeze plug will work until you get the cap figured out. You may can find a bolt that will work, or make one work.
Thank you for all the replies! Just to be clear, I'm assuming the plug unscrews. I'm going to soak it with Kroil again today and give each of these a try.
After the plug is out, and fluids drained, filter replaced, all the hose lines need to be replaced. I was going to replace them with Napa Auto Parts custom hoses. Seems to be the place to go for tractor parts in Southwest Washington State.
Thanks again for your help and I'll give an update as soon as I get the plug out!
/ FORD F 1700 REMOVING HYDRAULIC FILL PLUG #8
Yes it unscrews. So tap in the direction to unscrew it.
Uh oh... I believe this would've happened no matter what I would've done. Most of the cracking probably happened when I tried to loosen this a couple of years ago.
Next suggestions?
/ FORD F 1700 REMOVING HYDRAULIC FILL PLUG #10
Time for the chisel. It was a crap shoot either way.
2013 FORD F-350 FLATBED (A58214)
2013 FORD F-350...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A55745)
2014 MAGNUM...
240156 (A56859)
240156 (A56859)
2014 Caterpillar CB24B (A60462)
2014 Caterpillar...
2004 John Deere 4720 (A60462)
2004 John Deere...
