Is it worth it to have a slide out installed on a horse trailer?
   / Is it worth it to have a slide out installed on a horse trailer?
Efficient storage means stuff doesn't end up on the floor space.
I get that but the cots and cabinets on the opposite wall take up a bit of that floor space. Now, if we don't end up adding a slide, I would look at having cabinets and a window added above the cot area for more storage. Plus, that hay rack since it was mentioned and I forgot about that as an option. I would have to measure it again but I think ours is only a 4 or 6' shortwall.
   / Is it worth it to have a slide out installed on a horse trailer? #22
Thanks @bazman82. It sounds like you have done your diligence! If it were me, I would go weigh the trailer to see how much of that 10,700 budget you already use.
Upgrading the truck axles may help; I don't know your model, so I don't know how the frame differs between the 2500 and 3500 models. I know some Ford (diesel) owners who did that and they were happy with the upgrades since on their models the frames were identical. I also don't know the Kiefer frame/design that well, but I would be surprised if the frame could take the extra weight. Trailers tend to be engineered to the absolute minimum, whereas pickups often use the same frame for several different models, and have frames with "available" capacity. (That's a broad brush comment; I do not know your particular version.) A couple of other things that I would look at would be other upgrades, like bigger oil coolers for the engine and transmission, shocks/air suspension, and my go to, bigger brakes. I had an old Ford F-350 that the prior owner and me both beefed up it over time to improve trailering, but I think at some point it gets to the point where you need to step back and ask, "should I start over with a different rig?".
I get trying to use what you have. I try to do it myself. I'm just not sure that trying to up engineer the trailer makes sense. If it were me, I would look for a four horse LQ that is in the right load range and go from there.
We do endurance riding, so we do tend to trailer to the back of beyond, often over steep hills/interstates, so it does color my view of the world...
All the best,
Peter
All the best,
Peter
So all the research on the truck that I have done over the years was showing that our 2500 is the same as the 3500 just minus the extra leaf springs. Everything else is the same (engine etc). It wasn't until you get to the duallies and diesels that the engines differ. It's part of the reason we went with the 2500 back in 2015 because it fit our need at the time. I do have the RPO of our truck and can post the results of that if it helps any to see exactly what we have.
Also, I was just telling my wife that we should go weigh the truck and trailer to really find out what we are hauling for weight. I have a friend that does a ton of farming and I have been meaning to ask him if they had their own weigh station or if they used another families spot.
Vehicle: Listed Below
Year: 2015
Build Date: 2014-10-20
RPODescription
AG1ADJUSTER FRT ST POWER, MULTI-DIRECTIONAL, DRIVER MULTI-DIRECTIONAL PWR D/SEAT ADJR(AG1)
AKOWINDOW TYPE PRIVACY PRIVACY WINDOW(AKO)
AQQLOCK CONTROL, ENTRY REMOTE ENTRY, EXTENDED RANGE EXTENDED RANGE REMOTE LOCK CONTROL(AQQ)
AU3LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3)
AVFIDENTIFICATION EFFECTIVE POINT CONTROL, 2015 1/2 M.Y.
AXKVEHICLE TYPE TRUCK VEHICLE-TRUCK(AXK)
AY0RESTRAINT SYSTEM SEAT, INFLATABLE, DRIVER & PASS, FRT SIDE, ROOF SIDE DRVR & PASS FRT SIDE & ROOF INFLATABLE RESTRAINT(AY0)
AZ3Unk.
A31WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31)
A60LOCK CONTROL,RR COMPT, TAILGATE,KEY ACTIVATED RR COMPT LOCK CONTROL(A60)
A68SEAT RR SPLIT, FOLDING FLDG SPLIT RR ST(A68)
BTVCONTROL REMOTE ENGINE START REMOTE CONTROL ENGINE START(BTV)
BWNSTEPS CORNER ASSIST, BUMPER
B1JLINER FENDER FDR LNR(B1J)
B30CARPET,FLOOR AND WHEELHOUSE FLR CPT(B30)
B32COVERING,FLOOR MATS,FRONT AUXILIARY FRT AUX FLR MATS(B32)
B33COVERING,FLOOR MATS,REAR AUXILIARY RR AUX FLR MATS(B33)
B86MOLDING B/S COLOR BODY SI MLDG(B86)
CJ2HVAC SYSTEM AIR CONDITIONER FRT, AUTO TEMP CONT, AUX TEMP CONT A/C FRT AUTO/AUX CONT(CJ2)
CMDPLANT CODE FLINT, MI, GM T&B FLINT, MI PLANT CODE(CMD)
C49DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49)
DH6MIRROR,INSIDE,VISOR VANITY,RH AND LH(ILLUM) ILLUM S/S MIR(DH6)
DL8MIRROR,OUTSIDE,RH AND LH REMOTE CONTROL,ELECTRIC,DEFOG ELEC R/CON HTD O/S MIR(DL8)
DP6MIRROR PROVISIONS HOUSING, PAINTED PAINTED MIRROR HOUSING(DP6)
D75HANDLE O/S,DR,BODY COLOR O/S BODY COLOR DR HDL(D75)
EF7COUNTRY UNITED STATES OF AMERICA (USA) U S A(EF7)
E63BODY EQUIPMENT,FLEETSIDE PICKUP BOX FLEETSIDE PUBX(E63)
FHSVEHICLE FUEL GASOLINE E85 E85 GASOLINE VEH FUEL
GAZPRIMARY COLOR EXTERIOR, OLYMPIC WHITE (G) EXTERIOR COLOR(GAZ)
GEHGVW RATING 9, 500 LBS 9,500 LB GVWR(GEH)
GT5AXLE,REAR,4.10 RATIO 4.10R(GT5)
G80AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80)
H0UINTERIOR TRIM CONFIG CLOTH, LEVEL 2, JET BLACK INTERIOR TRIM STYLE(H0U)
IO5RADIO INFOTAINMENT SYSTEM - UPLEVEL WITH CONNECTIVITY UPLEVEL RADIO W/CONNECTIVITY INFOTAINMENT SYSTEM(IO5)
I15ENGINEERING YEAR 2015
JL1Unk.
J95BRAKE HYD POWER, SINGLE REAR WHEEL, 4 WHL DISC 4 WHL DISC BRAKES W/SINGLE REAR WHEEL(J95)
KC4Unk.
KI4RECEPTACLE ELECTRICAL, ACCESSORY 110 VOLT ACCESSORY - 100 VOLT ELECTRICAL RECEPTACLE(KI4)
KNPCOOLING SYSTEM,TRANSMISSION,HEAVY DUTY HVY DUTY TRANS CLG SYS(KNP)
KW5GENERATOR 220 AMP 220 AMP GEN(KW5)
K34CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)
K47AIR CLEANER HIGH CAPACITY HI CAPACITY A/CL(K47)
L96Unk.
MAHMARKETING AREA NORTH AMERICA NORTH AMERICA(MAH)
MYDTRANSMISSION AUTO 6 SPD, HMD, 6L-90 6-SPD A/TRANS(MYD)
NE1CERTIFICATION EMISSION, GEOGRAPHICALLY RESTRICTED REGISTRATION FOR VEHICLES UP TO 14, 000 LBS GVW (USE 2 RESTRICTED REGISTRATION EMIS(NE1)
NP5STEERING WHEEL,LEATHER WRAPPED LEATHER WRAPPED STRG WHL(NP5)
NQFTRANSFER CASE ELECTRIC SHIFT CONT, TWO SPEED, ALUM 2-SPD ELEC SHIFT TRANSFER CASE(NQF)
NU1EMISSION SYSTEM CALIFORNIA, LEV2 CALIFORNIA LEV2 EMIS(NU1)
NZZPACKAGE,OFF ROAD SKID PLATE,SPORT SKID PLT PKG(NZZ)
NZ4WHEEL SPARE FULL SIZE, 17" STEEL FULL SIZE SPARE WHL(NZ4)
N37STEERING COLUMN,TILT AND TELESCOPING T&T WHL(N37)
PCMCONTROL - SALES ITEM NO. 106
PPAEQUIPMENT ASSIST, OPEN & CLOSE, TAILGATE OPEN & CLOSE TAILGATE ASSIST(PPA)
PYQWHEEL 17 X 7.5, ALUMINUM, PREMIUM, HD 8 LUG ALUM WHL(PYQ)
QHQTIRE ALL LT245/75R17 E 121/118 R BW ALS TIRE(QHQ)
R9NCONTROL - SALES ITEM NO. 89
SAFLOCK SPARE TIRE, HOIST SHAFT SPARE TIRE LOCK HOIST SHF(SAF)
SLMSALES PROCESSING - STOCK ORDERS
TG5PLAYER COMPACT DISC AND MP3 COMPACT DISC & MP3 PLAYER(TG5)
TRWPROVISIONS LAMP, ROOF MOUNTED RF MTD LMP PROV(TRW)
T3ULAMP FRT FOG FRT FOG LAMP(T3U)
UDDDISPLAY INSTRUMENT DRIVER INFO ENHANCED (MULTI COLOR GRAPHIC) DRIVER INFO ENHANCED DISPLAY(UDD)
UE1COMMUNICATION SYSTEM VEHICLE, G.P.S. 1 GPS 1 VEH COMM SYS(UE1)
UJMTIRE PRESS INDICATOR MANUAL LEARN MANUAL LEARN TIRE PRESS IND(UJM)
UK3ELECTRONIC SYSTEM,ACCESSORY CONTROL ELEK ACSRY CONT SYS(UK3)
UMNSPEEDOMETER INST, MILES & KILO, MILES ODOMETER MPH & KPH SPEEDO W/MILES ODOMETER(UMN)
UQ3SPEAKER SYSTEM,PERFORMANCE ENHANCED AUDIO ENHANCED SPKR SYS(UQ3)
UTJTHEFT DETERENT ELECTRICAL, UNAUTHORIZED ENTRY UNAUTHORIZED ENTRY THEFT DETERENT(UTJ)
UVCCAMERA REAR VIEW REAR VIEW CAMERA(UVC)
U2KDIGITAL AUDIO SYSTEM S-BAND DIGITAL S-BAND AUDIO SYS(U2K)
U73ANTENNA,FIXED FIXED ANT(U73)
VJHBUMPER RR CHROME CHROME REAR BUMPER(VJH)
VK3LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3)
VRKVALUE ADDED ASM ROOF TRIM UPLEVEL ROOF TRIM(VRK)
VT7OWNERS MANUAL ENGLISH LANGUAGE ENGLISH LANGUAGE OWNERS MANUAL(VT7)
VV4Unk.
VYUPROVISIONS,SNOW PLOW SNOW PLOW PROVISIONS(VYU)
VZ3LABEL MERCURY DISPOSAL NOTIFICATION MERCURY DISPOSAL NOTICE LABEL(VZ3)
V22GRILLE,RADIATOR(CHROME) CHROME GRL(V22)
V46BUMPER,FRONT(CHROME) CHROME FRT BPR(V46)
V76HOOK,FRONT TOW FRT TOW HOOK(V76)
V8DVEHICLE STATEMENT US US VEHICLE STATEMENT(V8D)
WMFVIN MODEL YEAR 2015
XL7FREQUENCIES RATING 315 MHZ LONG DISTANCE 315 MHZ FREQ(XL7)
X88CONVERSION CHEVROLET CHEVROLET(X88)
YE9CONVENIENCE PKG COMFORT & DECOR LEVEL #3 COMFORT & CONVENIENCE PKG #3(YE9)
ZHQTIRE SPARE LT245/75R17 E 121/118 R BW ALS SPARE TIRE(ZHQ)
ZY1COLOR COMBINATION SOLID SOLID PAINT COMBO(ZY1)
Z82TRAILERING PACKAGE(SPECIAL)(REESE TYPE HITCH) PROVISION FOR HD TRAILER EQUIP(Z82)
Z85CHASSIS PACKAGE,INCREASED CAPACITY CHAS PKG(Z85)
1LTPACKAGE LT OPTION 1 "LT" PKG(1LT)
1SZPACKAGE OPTION- (1SZ)
4AAINTERIOR TRIM JET BLACK INT TRIM COLOR(4AA)
8X2COMPONENT RR LH NON-COMPUTER SEL SUSP SUSP(8X2)
9X2COMPONENT RR RH NON-COMPUTER SEL SUSP SUSP(9X2)
   / Is it worth it to have a slide out installed on a horse trailer? #25
In this day and age, I'd want the kids inside the camper at night in any public campground.
   / Is it worth it to have a slide out installed on a horse trailer? #26
We have a 2003 Keifer genesis4 (could be wrong on the number). It is a weekend package so the interior is bare.
If you’re willing to pay for and do the upgrades, I would. I replaced a shadow 7’6” wide with a lakota 8 foot wide and 9’ slideout. Yes, you lose floor space while moving it (im not riding in it so…) but when opened up its a huge difference, especially on a rainy day.
FB page - horse trailer conversions II has some pretty cool diy upgrades.
   / Is it worth it to have a slide out installed on a horse trailer? #27
I guess everyone is different. We have horses and I wouldn't want to sleep breathing the ammonia, flies and manure.
Having what you already have, horse & people trailer I'd just use that, two trucks, two drivers.
Or stay in a motel (the best).
Or sell everything but the trailer buying a good new/used RV (one like Verona Super C diesel motorhome...very low miles ones for $200K), towing horses with it.
Us, it would be truck, horse trailer, motel.
   / Is it worth it to have a slide out installed on a horse trailer? #28
The horses are normally out of the trailer when camping. There has been occasion to keep them on but its rare. There is a divider to separate people side from horse side.
There is a divider between the people area and horse area. You would never smell anything unless you left the horses on their for days and didn't clean it.
We thought about getting a 2nd truck (1500) to haul the camper. It only weighs 5k dry or we do have a 3 horse bumper pull that is used for most running around and quick pick ups and cows. But...its not economical as a daily driver and our commute is 50 miles round trip. I mean, we could possibly trade in our subaru for a 1500 and get an old beater car as a daily commuter vehicle but we would miss some of the luxuries of the subie. I'll run that by the wife since it really doesnt sound like a terrible idea.
I was looking at Super C class RV's that could tow our 3 horse bumper (max loaded would be around 6-8k). Most that would've been in our price range didn't have that towing capacity. 200k for us, is out of the question. Even 80k is pushing it but because we could possibly have 25k worth of trade between the 2 trailers for a trade in, we were considering it.
   / Is it worth it to have a slide out installed on a horse trailer? #30
Found on RacingJunk.com
Sleeps up to six, 100gal diesel, 75 gal water, shower, toilet, gas stove, fridge/freezer, gooseneck hitch, or bumper pull.
Freightliner Fl70 frame, automatic transmission, differential lock for lousy surfaces (awesome feature, BTW)
Does a U-turn in three lanes. Hauled a 70,000lb race trailer from New York to San Diego with no issues.
It took me something like 18 months to find one at a price I wanted pay, and it ended being about half the price of a new F-450. 70,000 miles on a CAT3126 engine, which is nothing. Funny thing was I tried to buy the same one twice- once from the original owner, and then successfully from the dealer who got it from him (but at a lower price than the owner was willing to settle for. Go figure.)
I just think that there are out of box solutions that have the potential to be better/cheaper.
All the best,
Peter
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
2018 INTERNATIONAL LT625 TANDEM AXLE DAY CAB (A51219)
2018 INTERNATIONAL...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
CHALLENGER MT465E TRACTOR (A51406)
CHALLENGER MT465E...
2015 KENWORTH T800 MID-ROOF SLEEPER (A50854)
2015 KENWORTH T800...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
