New Holland 2120 PTO not engaging
/ New Holland 2120 PTO not engaging #1
Trent1
New Holland 2120
I have a 1997 New Holland 2120 that’s not engaging the pto. It is shuttle shift and I can’t turn the pto shaft counter clockwise it only will go clockwise so I think the one way clutch should be good? The clutch in the tractor seems like it’s engaging good with no slipping if anyone has experience with this and can help me know where to look I’d really appreciate it.
/ New Holland 2120 PTO not engaging #2
Welcome to TBN. One way clutch??? With the tractor off, can you turn the PTO both ways?
Hyd Shuttle should have a single disc clutch so your observation of the clutch eliminates that as a source.
No with the tractor off I can’t turn the pto counter clockwise only clockwise. I wasn’t sure if it had something to do with the hydraulics?
/ New Holland 2120 PTO not engaging #4
So the PTO on the HSS shuttle uses an overrunning clutch internally. That is why you can only turn it one way with the engine off. The PTO splines into the clutch. When the clutch is depressed half way, the hydraulic dump valve stops the tractor. When it is fully depressed, it disengages the main clutch and stops the PTO .
/ New Holland 2120 PTO not engaging #5
Does the PTO coupler feel like it is engagimg?
I hear an audible click when I disengage and engage the pto as if it’s falling in a de dent ball. So is there another way to check the one way clutch other than tractor off pto engaged like I already tried?
/ New Holland 2120 PTO not engaging #7
Have someone depress the clutch pedal all the way and try it again.
/ New Holland 2120 PTO not engaging #8
@TractorTech I was wondering if you can help me out with a sprag clutch repair/replacement on a 2120 Ford. Does the Counter shaft (#6) typically need replaced as part of the repair? or is it the bearings, clutch and collar only(#s 25, 26, 11, 10 and 12) ?
  • Ford 2120 Sprag Clutch.pdf
/ New Holland 2120 PTO not engaging #9
Welcome to TBN!
Not real sure on this one, but being that #6 is unavailable, it doesn't make too much difference.
/ New Holland 2120 PTO not engaging #10
I doubt there is a "typical" repair for that. Get your defective parts out on the table then decide what you need.
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2015 Acura ILX Sedan (A59231)
2015 Acura ILX...
2015 BMW 328i Sedan (A59231)
2015 BMW 328i...
2018 Dodge Grand Caravan SXT Van (A59231)
2018 Dodge Grand...
2018 Husqvarna 21in. Push Mower (A59231)
2018 Husqvarna...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
