Good morning!!!!
   / Good morning!!!! #171,131
Good Morning!!!! 59F @ 6:45AM. Plentiful sunshine. High around 85F. Winds SSW at 5 to 10 mph.
Sorry about the noisy neighbors, JKC. Some people have no consideration, not even for themselves.
Do you have access to the back of the panel you're trying to repair, Drew? If so, clean it up very well with a strong detergent, let it dry, and build up a few layers of fiberglass cloth applied from the back. Then you can grind out all the pieces of broken 'glass on the surface, and use body filler or fiberglass to restore the contour. Fill any pinholes with surfacing putty, then a good coat of high build primer. Maybe too late for that, though. A good automotive paint store will be able to mix paint to match any color and pump it into an aerosol can for you to spray. They can even do a two part acrylic if you like. But I also like the idea of aluminum tread plate patches over both corners...
Kyle wrote:
RNG, glad you are taking your time finding a van....I know you only want to buy once. I've found that I prefer most options....until they break. Most will last.
I'm reading about odd problems with the software and how it interacts with the braking and steering systems. Reports of the anti-sway feature pushing the van over the centerline when trying to pass a semi truck. That's a pretty serious bug.
Yesterday was all about vehicles. Dug the pressure washer out of the storage trailer and puttered around, getting it ready to try out the foam cannon on the Camry. Took a bit of encouragement to get it going after a long time of no use, but it eventually caught. Used a 40° tip and wet it down well, then made up a batch of "Sticky Snowball" soap from Chemical Guys and gave the cannon a try. Didn't use enough soap to get the fluffy blanket shown in the videos I've watched, so put more in the next batch. Better, but not great. Looked at the video again, and he's using way more than the recommended amount (2 oz/liter vs 1-2 oz/5 gallons). I'll try that next time.
Once I let the car dry off for a bit, I got out the new car cover and put it on. First time backwards, but it was easy enough to swap ends and get a much better fit. It's some kind of plasticized fabric with a thick fluffy liner, so I'm hoping it holds up better in the sun than the thin nylon ones I use on the motorcycles. But anything's better than nothing.
That all took way longer than I thought it would, and after a late lunch, decided to dig in to the list of white painted vans, of which there are hundreds, instead of tens for the colorful ones. Turns out it's pretty rare to find a dolled up white one, and most are strippers intended for trade use. Unfortunately the search tools I have access to don't discriminate to that level, so I'm having to download the Monroney sticker for each one to see if the must haves are there. I got through 170 of them yesterday, and sorted by distance, I'm into western Colorado. The only one with the right options was built on the shorter wheelbase, so it was a nogo as well. But I still a long way to go, so there is still hope. And maybe the local dealer will come back with some good news on a quote.
I'll walk the trimmer this morning, then head into town for groceries this afternoon. Got a little extra shopping to do as an old college buddy is supposed to drop by for a few days next week, and I know he likes to eat well.
Hang in there, gang, Friday's comin'!
   / Good morning!!!! #171,132
Dennis- Great job on beefing up the structure..
Rich- Decent looking top link setup.
RonJH, Ken, Fritz, Dennis, and anyone else that I missed- Thanks for sharing your various pictures
Drew- Your repair is coming along nicely.
I ended up taking some liquid decongestant early this AM due to today's smoke. I did not smell any this morning, partly due to the flowering lilacs' and Autumn/RussianOlives' perfume. It was another hazy/veiled sunshine morning with 50ºF as this morning's low temperature and today's predicted high will be ~90ºF. I can not believe the duration of this Rex Blocking pattern. There was enough particulate matter in the air to mess with my camera's auto-focusing this morning. I have a couple of AI bird ID apps and it appears that this property is surrounded by Red-eyed Vireos based on song; I have never seen one.
Due the proximity to an active bird nest. I am holding off on switching the tractor's box scraper blade for the tiller until the House Wrens young fledge which may occur soon.
I too am hoping for some decent precipitation Friday-Monday.
Friday may prove to be "interesting" weather-wise with a fair chance for a decent T-storm or 2.
   / Good morning!!!! #171,133
Good morning! Low of 49°, going up to 73°. A slight chance of a sprinkle and maybe a t-storm this afternoon. Mostly cloudy so far this morning.
Kyle, enjoy the fishing trip with your son. Hope he catches "the big one"!
Drew, looks like the repair is proceeding nicely. Armored corners or a BIG bumper might prevent further body work....
Paul, glad to hear you're feeling better. Hopefully you are "over the hump" and will be back to normal quickly.
Dennis, that was a lot of cutting. Definitely a good amout of seat time. Good that the mower was fixed fairly easily.
Ken, I can understand why the deer hang around... beautiful yard area. Who wouldn't want to browse there!
RNG, hope your persistence pays off and you find that "perfect" van. It's out there.....
Jay, hope you're able to get outside to enjoy the birds and the smoke doesn't hinder the observation. The national news had a story reporting the smoke was traveling as far south as the Delaware Valley.
I still didn't get that planter filled..... but I did get all the zones irrigated.
Then took the time to mix up some insecticide for the fruit trees. Did one tree at a time, mixing the proper amounts in a 5 gal bucket. Then that got poured around each tree. I'm glad it's only a once a year procedure.....
Went and picked up the tubing needed for the drip irrigation extensions to the planters done last week. Pulling a 100' garden hose gets old fast....
While at the garden center, noticed a couple "odd looking" evergreens over in the corner. They were "Altos Blue Sequoias". Came home and researched if they would grow here..... and found out there are a few growing in parks in Santa Fe.
The wifey was looking for a unique 'specimen tree', so I got sent back for one. It's about 5' tall, looking at prices online, could be as high as $250.... I paid $40. Even HD was $80 for a 2ft tree.
Not sure if it will survive, but it sure will be a conversation starter if it does..... I think it will require some TLC to get a strong hold.
The strawberry planter WILL get filled today. Hopefully will get the plants transplanted too. Might get to hooking up the drip on the planters.
The Purple Robe Locust is in full bloom. Most of the 'spring' flowers are done, now the 'summer' flowers are bloomed. Wifey's seeds have popped in the greenhouse.... next season's plantings......
Did some snake wrangling yesterday.... I was walking across the drive and there he was, warming in the sun.... a 5' Bull snake. One of the "good" snakes (If there is such a thing). He got relocated out in the field. I'm glad it wasn't a rattler..... I walked right up to him before I saw him.....
Gonna get myself in gear.... lots of stuff to struggle with.... I hope I don't get sidetracked again....
Everyone have a great day!
   / Good morning!!!! #171,136
66°F and .45 inches rain.
Mowing done, major mind shift ahead. Friend Lenny called to say they are on island and we get together tomorrow to game plan the house painting. I want to be fully prepped so that’s what I’ll be working on. Pretty sure I have all the materials laid in.
H&F later today at friends. Time for the guys to be victorious 🤞
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #171,138
   / Good morning!!!! #171,139
RNG- Your van research is fascinating as well as scary as it relates to those software glitches affecting performance. I hope you find the van you envision..
Tom and Ken- The NWS is getting so used to this smoke plume that they refer to it as haze or at least the Boston-Norton Office does. I was huffing and puffing this morning during the pre-dawn 🐕 tour of the lower perimeter which is very unusual nowadays.
Ted you and Dona and family have truly created an oasis paradise in the middle of the desert. Thanks for sharing. The last time I wrangled a snake, a big @r$e rat snake, the outcome proved to be a draw. I caught him and then he caught me. That did hurt. They do stink when agitated. I should have not been holding that G&T 🥃 during the encounter. Our friends who were visiting were "impressed."😲😱 Maybe the snake won in hindsight.
Dennis- Turkeys can run ~35mph. :cool:
Now that I am delaying getting the tiller going I will need to pot the basil starts; maybe repot the tomatoes as well.
A pair of Tree Swallows attempted to take over the active Wren house. It did not go well for the TS's. I wish I had the camera with me.
85ºF here ATM.
I hoe that everyone has a manageable day today.
   / Good morning!!!! #171,140
84F and sunny @ 13:00 ... HI 82F - DP is 51F, 32% humidity ... :oops:
We are currently under an Air Quality Alert (for ozone)
Got some more seeds planted last night: the "Casper" pumpkins (which are white) and Strawberry Crown winter squash.
Also had to do some replanting ... didn't get the garage door closed before dusk and something got into a few of the pots I had planted seeds in. Suspect it was a 'coon. Need to straighten out trip wire for live trap.
Oddly enough in the couple pots I have checked so far, the seeds were not eaten.
Woman had set a plastic bag of sliced Honey Dew melon which was old out in the garage, probably to go in the compost. Whatever it was got into that and made a real mess ... 🤬
She is out right now picking some groceries for me to tide me over while She is gone, as well as more cat food so I don't have to run out for that.
Big task for today will be to get all those planted pots which are in the garage put into the dump cart and transferred around to the back and then get them set out on the shelves where they can bask in the sun.
Probably get the asparagus roots unbagged and put in some water to soak as well.
Maybe get one of the new blueberry bushes and some rhubarb planted.
Get the loader on the Kubota greased.
Have doctor's appointment later today, thankfully they were able to get me in on short notice.
Hope everyone is having a great Thursday ... (y)
2024 Quality Steel Deck Over Tilt Trailer (A59814)
2024 Quality Steel...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 Ford Transit Connect Cargo Van (A56858)
2019 Ford Transit...
2009 Ford F-150 Crew Cab Pickup Truck (A56858)
2009 Ford F-150...
2018 F150 (A56436)
2018 F150 (A56436)
2012 Western Star Trucks 4900 SA Truck, VIN # 5KJJALDV0CPBE2239 (A57453)
2012 Western Star...
