What type of metal to add for the brush guard?
   / What type of metal to add for the brush guard? #11
Perforated steel is another option. McMaster sells that also.
I like perforated better. Looks better IMO. 14 or 16 gauge with 1/2" holes
   / What type of metal to add for the brush guard? #12
I do too, if I do a insert I more than likely will use that instead of expanded. May go a bit smaller on hole size , just not sure yet.
   / What type of metal to add for the brush guard? #13
I made mine out about 1 inch expanded metal. 7-14-11 Grill with Expanded Metal.jpg I also added bracing before adding the expanded metal. Smaller would have worked, but I didn't want to obstruct the lights. Any quality mill supply will have samples you can look at to decide what you want.
hugs, Brandi
   / What type of metal to add for the brush guard? #14
I used a non- flattened expanded metal. It's very heavy and open, but I installed it on both sides of the guard and slightly staggered. I wanted it really strong, so I wouldn't have to replace later. It's called 3lb grating. It's a 1/4" thick steel plate prior to expanding. The openings are 1" x 3 1/4" +/-.
   / What type of metal to add for the brush guard? #15
Yes, I realize I am bumping an 8 year old thread. I am looking for just this information and wondered if anyone had more to add.
I found both perforated and expanded metal on metal depot. About 260 for perf or 100 for expanded (2'x4').
Thoughts and ideas are welcome.
   / What type of metal to add for the brush guard? #16
I went to my local welding fab shop.
Got 24x28 1/8 inch, then ACE hardware for u-bolts and mounted up.
Then clearing a stormed broken limb the broken portion swung into grill and put a nice dent!
But save the front end.
So if you have a local fab shop talk to the floor hand for a look and then make the buy.
You'll have peace of mind in a few hours. Ya gonna paint it orange right? heh of course....!
   / What type of metal to add for the brush guard? #19
I bought this for my tractor and also the matching chain bucket. It holds 20’ of chain. Perfect. He will also do requests for products for other tractor brands than Kubota. A simple drill of the factory grill guard and bolt on.
   / What type of metal to add for the brush guard? #20
Do a lot of limb work with grapples. Gravel screening from scrap yard provides industrial strength protection for $.30/#. Be sure to add protection from coming up from underneath too.
2019 BOMAG BW120AD-5 SMOOTH DBL DRUM ROLLER (A52707)
2019 BOMAG...
Diamond C Trailers 26ft T/A Flatbed Tilt Trailer (A55787)
Diamond C Trailers...
Bell B30E (A50123)
Bell B30E (A50123)
2016 TRAILSTAR 40FT DUMP TRAILER (A56129)
2016 TRAILSTAR...
2012 Chevrolet Silverado 3500 HD Enclosed Knapheide Service Truck (A55973)
2012 Chevrolet...
Caterpillar 420F2 IT (A53314)
Caterpillar 420F2...
