sandman2234
Super Member
- Joined
- Dec 4, 2005
- Messages
- 6,590
- Location
- Jacksonville, Florida
- Tractor
- JD2555 and a few Allis Chalmers and now one Kubota
I am wondering...
Since the lift arms came down when the head was off, is there a possibility that there is something clogged up in the return oil system? The oil has to go somewhere, and while it took some effort, the lift arms did go down when the head was off. In hindsight, I probably should have cycled the lift arms up and down several times in order to free them up, but was just so glad to have them go down, that I didn't think about it. Had I cycled them up and down several times, it would have eliminated Harry in Ky's (and mine) thoughts that the splined shaft called rod (4) is stuck in the bushings. Now realizing that the bushings are there and it is not shaft to housing (dis-similar metals), I now realize it isn't steel to aluminum. However, the rod to bushing could still very easily be stuck.
When running, as I raise the handle to raise the lift arms, I can hear the diesel engine loading down, and if I lower it, the diesel engine loading sound goes away. So while that should mean something, I am not completely sure exactly what it means.
1) is the pump loading to max and stalling?
2) is the unit low on fluid and unable to pump the volume of fluid that is needed to actually move the cylinder?
3) If the return oil port is clogged, would that matter as long as the piston was in the up position? Seems like fluid would continue to pump into the cylinder chamber, thereby pushing the lift cylinder down before a clogged return port would matter.
4)Due to it's being left in the auxiliary position for an unknown amount of time, is it possibly that the pump has been damaged, and will pump volume but not pressure?
5) Is a relief open somewhere, not allowing fluid pressure to build up?
6)Is something in the head, such as the hydraulic valve (21) not installed correctly? I removed it, and replaced it, and there doesn't seem like anything is out of place. However, since it has been gone into before, it could be me missing something.
I am thinking my next moves should be to go after hydraulic fluid, figure out what I did with the broken dipstick (currently has a rubber freeze plug in hole to prevent rain and dust from entering) and get the hydraulic fluid level up to the correct level. Start tractor and see if anything happens when I raise the lift arms.
If nothing happens, pull the head back off and see if the lift arms can be raised and lowered with the M7040, and then cycle it a few times.
I priced the lift shaft assembly in a used part, when I was looking for a dipstick. It wasn't as bad as I expected, only $800! However, they want a $600 core charge on it, which means I have to ship the old one back, plus loose those extra parts. Plus, with these additional parts costs, I am exceeding the value of a running tractor with what I have invested in it, something I was hoping not to do.
Thanks for all the help!
David from jax
David from jax
