Echo CS-7310P Pro Chainsaw: Questions & Thoughts & Things You`ve Done With Yours.
   / Echo CS-7310P Pro Chainsaw: Questions & Thoughts & Things You`ve Done With Yours. #1
BX23S-1
No Clue
Kubota BX23S
Hello folks
I just bought a brand new Echo CS-7310P saw. (20" bar 3/8 .058 ga) This saw starts very well, runs very good.
I would like to hear from the folks in here if they have this particular saw, and what they think of it after running it for awhile.
The saw is only using VP 50:1 Fuel in the 1 gallon tin can. I did pick up a 6-pak of the Echo Premium 2 stroke oil to mix (NON CORN) fuel later on after the VP fuel is used up.
Muff Mod: Is the muffler mod really worth doing? Anybody have pics of their muffler mods? How does your saw run after the muffler mod? Was there that much of a difference?
I`m not into porting the saw, so as to make that clear right off the bat. I cut trees down for firewood when needed. I saw up storm damaged trees. I`m not interested in costly porting mods.
So far, mine is untouched, exception to adding the Westcoast 3 Bark Dogs.
Be very careful if you decide to change out the bark dogs, Echo really dumped gobbs of some form of white loctite in the bolts to the inner dog.
When i took the OEM dogs off mine, the top inner hole stripped most of the thread out of the case just getting the bolt out. I had no clue they filled these holes so full of loctite.
I was able to run a tap in the holes to clean up Echo`s loctite mess. When i installed the new WC3 dogs, i used loctite when i put the inner dog bolts back in the case.
The outside dogs have a bolt and a nut, (nuts are hidden behind the nylon chain guides within the chain case cover) those were no problem removing/reinstalling when i installed the WC3 dogs.
What chains are you running, or have tried. What worked best for you. I picked up a couple extra of the Oregon 73EXL chains for mine. Haven`t tried those yet.
I noticed right away, that the OEM bar seems a bit stiff in certain spots. I`m trying to find a better quality bar for it, not had great luck finding any in stock though.
I hand file my chains, always have. Maybe someday i`ll step up to a grinder. They seem quite pricey though, so i`ll hold out on that for awhile. Might find a nice used one somewhere.
Does anyone know who makes a hard-shell case that actually fits these saws? I`ve had zero luck finding any.
This thread is intended to talk about the Echo CS-7310P & CS-7310PW Pro saws. I`m not interested in conversations about other brands as a comparison. Thank you.
I`m looking for the part number for the Tsumura 28 inch (light weight) bar.
If there are better bars than this for this Echo CS7310 saw, i`m all ears.
   / Echo CS-7310P Pro Chainsaw: Questions & Thoughts & Things You`ve Done With Yours. #3
I've had the Echo 680 for 6+ years, still stock and using standard 20" bars and chains. I'm happy with the saw. A logger friend borrowed my saw for a day and the next day bought his own 680 with a 28" bar. 5 years later it's still in use daily.
It's a heavy saw, great for felling and bucking. I reach for a smaller saw for limbing and cutting small stuff.
I only run echo 2 stroke oil and ethanol free gas. The logger uses ethanol gas and the cheapest 2 stroke oil he can find. Neither of us has had any issues. I've worn out many chains, and a few bars.
   / Echo CS-7310P Pro Chainsaw: Questions & Thoughts & Things You`ve Done With Yours. #4
SawAgain as well as Baileys and Saw Salvage sell lighter weight replacement bars. Far as chains go, I now make up my own, saw chain is cheaper in bulk rolls but you need a rivet spinner to make them up.
At least all the Echo 'Pro' saws don't have built in cats in the mufflers and neither does the 590 I just bought.
Far as chain grinders go, I now have 2 because everyone around here (as well as the arborists) I sharpen chipper knives for, have discovered I sharpen chain loops so I seem to have a ton of loops hanging in the shop presently to sharpen...lol
I took a change and bought a second grinder as the Oregon grinder (which is a Tecomec rebranded to Oregon) is quite expensive. I bought a 'Veyvor' off of Amazon and it was 100 bucks and an exact Chinese copy of the Tecomec/Oregon.
Works very well and actually, the chain vise is more substantial than the Oregon and grips the chains much tighter.
I have one (Veyvor) for grinding teeth and I use the Oregon / Tecomec for setting rakers and both are running the Diamond Wheel, Inc., CBN wheels. The CBN wheels are a bit pricey but never need profiling unlike the OEM stone wheels.
If anyone wants the OEM stone wheels, I'll send them to you as I have quite a few that I'll never use.
The 680P was what i went to buy because i got tired of waiting for the CS7310 saws to show up, and low an behold, i walk in the echo dealer, and they were setting a brand new CS7310 on the rack that had just came in that morning. I wasn`t leaving without it.
   / Echo CS-7310P Pro Chainsaw: Questions & Thoughts & Things You`ve Done With Yours. #6
I've 'coerced' my Kubota dealer into carrying the Echo line of saws, trimmers and blowers. They are looking for retail dealers in this area and he already sells Cub Cadet mowers and tillers so why not.
I find Stihl to be overpriced and over rated anyway. Why pay 50% more for a comparable Stihl? Makes no sense to me.
Have not even fired the 580 I bought. Waiting for the air cleaner mod as well as the Billet aluminum muffler deflector and the offset key to show up.
7310 is a bit big for my use, the 580 is just the right size for my uses. I like a 20" bar myself.
Thank you for your post, very informative! I don`t cut enough firewood to make it worth having a large bulk roll of chain sitting around, let alone all the tooling to make complete chains. I`ve always held off even buying a grinder. I don`t run my saws hard. A quick touch up on the chains keep me rolling for what i have to do. What i DO want, is a better, lighter bar. A lighter 28" bar will hopefully still keep this saw pretty balanced. The 20" on the saw right now, is perfectly balanced, and i like that. So by putting a light weight 28" on it, will hopefully bring a nice balance to it. I`ll check out those 2 you mentioned about the bars. Thank you for that! I`m kinda new to the Echo chainsaw brand, and still learning. I`ve owned Stihl saws for over 40yrs, but they`ve gone beyond what i want to pay for a decent pro saw. I own a couple old Echo weedeaters i`ve had for many decades, they refuse to die, lol, still using them today! When i saw that the echo`s were still made in Japan, i knew i couldn`t go wrong with the brand. I know the echo saws are bogged down due to EPA (ridiculous) rules, but as i say, i`m old, and i`m not into chainsaw racing. I want reliability, and to also be able to adjust the carb mixtures to my liking. I`m not a fan at all with all this electronic carb tune stuff. Just more stuff to go wrong in my opinion.
Tell me how i would benefit by going to the .050ga vs the .058ga bar an chain.
Seems the standard is geared more towards the .050ga rather than the .058ga with alot of saws. Mine came with the .058ga.
Would i have to change the clutch sprocket if i switch to the .050ga ?
   / Echo CS-7310P Pro Chainsaw: Questions & Thoughts & Things You`ve Done With Yours. #9
depends on how the drive tangs are configured.
   / Echo CS-7310P Pro Chainsaw: Questions & Thoughts & Things You`ve Done With Yours. #10
I still own a couple Stihl's but won't buy any more. Good saws just over priced today. I used to be a devout hand filer myself but the inherent accuracy and repeatability of a chain grinder far exceeds any hand filing, jig or not... and just because your grind the chain, don't mean you have to remove a substantial amount of tooth each grind either. The amount of tooth removal is entirely dependent on how much you advance the tooth into the grinding wheel and that is controlled by the tooth pawl on the machine.
I just advance the tooth to where the grinding wheel just contacts it and then a tad bit more, unless of course you 'rock' a loop, then you have to determine the 'bad teeth' and advance the teeth to restore them as well as the rest of the loop.
One thing to keep in mind and that is, you only grind a little at a time with each grind pass or you'll 'blue' the teeth and unlike the You Tubers say, bluing a tooth don't make it soft, on the contrary, it makes them harder and if you harden them, you cannot hand file them ever again.
Very careful about not getting into dirt when bucking but there is always a chance that there will be something metal in the wood you are cutting and that will also 'rock' a loop.
I have a buddy who runs Carbide saw chains. With a carbide chain, you have to dress them with a Diamond wheel and Diamond Wheels, Incorporated also sells diamond dressing wheels (what he uses). The rakers on a Tungsten Carbide chain will still be mild steel. Nice thing about carbide teeth is, they last a long time but the initial expense is quite high.
I believe that is what fire departments run when they cut into roofs during a fire. Roofing will dull a conventional chain very quickly. Kind of like putting a saw chain in the dirt or hitting something metal (like a nail) in a chunk of wood you are cutting.
One thing about professional arborists, when they dull a chain, they just change them out for a new loop but new loops are getting pretty expensive so I'm getting regrinds from the arborists I sharpen their chipper knives for. Stand to reason that regrinding chains is more cost effective than buying new loops.
The only chains that are a PITA to regrind are the low profile, reduced kickback PICO chains and not because of the cutting teeth but because their Rakers are odd shaped, but then most professional arborists don't use them anyway.
I checked out Baileys and SawAgain, doesn`t look like they`ll be getting any money from me, their prices are quite a bit higher than other places. And charge you shipping on top of your order.
I found another place that has quite a bit cheaper prices, and free shipping on anything you buy from them, and most of what i want, is in stock. They don`t have the 28" Tsurmura or Surguri light weight bar i would like to have. This saw is still new to the industry. It`ll take more time to catch up to the other brands that they make them for. I could get the adapter for the bar so i can run a Stihl bar on it, but i`m not a fan of doing that. (this bar is a D009 tail mount) I`ll post who the other place is AFTER i buy from them. I don`t want to post a link and send people someplace that i haven`t fully checked out to see for myself to make sure they are reputable and with quick service. Basically, i`m saving others the trouble, if they suck.
   / Echo CS-7310P Pro Chainsaw: Questions & Thoughts & Things You`ve Done With Yours. #12
Here is the stock dyno runs. The 7310 is down on power compared to others and tad heavy. Last in hp and torque.
Great built saw with a great air filter set up.
They take to porting big time if done by right porter.
View attachment 802692View attachment 802693View attachment 802694
Great post, and thank you!
Yes sir, i knew in stock form it wasn`t the power house like many others out there in its class. And its nice that Echo left alot on the table for others to do wild stuff to these saws, and the dyno results prove that in many videos i`ve seen. The EPA is the killer of these saws. The main reasons i bought the saw was Echo`s reliability and build quality, and its made in Japan, not chy-knaw. And i only paid $849 for the saw brand new a couple weeks ago.
I could have spent twice as much money on a Stihl (which i am a fan of and i own some Stihl saws), but when you look at what your getting in the Echo pro saw, for the money, why would i spend gobbs of money on the Stihl or Husqvarna brand. Not bashing those brands either, both are GREAT saws. It came down to the money, and the Echo brand just made sense, to me, dollar wise. I live on a fixed income, so money matters (the cost of porting this saw isn`t going to happen). I`ve done alot of research on the Echo saws, and there are lots of very happy Echo chainsaw owners out there. I`m still running a 30+yr old Echo weedeater, thats never been torn apart nore updated, to this day! Now thats what i call reliability. I`m pretty sure that this Echo pro chainsaw will surely out live, me, lol.
I have no plans on porting this saw. I`m just an old retired guy cutting small amounts of wood each year, some storm clean up`s occasionally. I`ve got alot of time on my hands and i have no intrest in saw porting just to make the saw run faster/harder. Many have said just a simple muffler mod, tune the carb, wakes these saws up pretty good, but thats about as far as i would go with anything with this saw. I`m just not into the cookie cutter racing.
The best thing i love about the saw, is NO ELECTRONIC carb BS to deal with. I only use the saw at home, no elevation changes, dial the carb in once in a great while and just go to cuttin. I`m old, so old skool ways have never failed me, yet. I`ll leave all the fancy electronics and computerized gadgets to the younger kids. I`ve always found, that a good sharp chain is key, for me.
Do you happen to have any dyno information to prove what a muffler mod does for these Echo CS-7310 saws? That would be more my flavor and intrest.
   / Echo CS-7310P Pro Chainsaw: Questions & Thoughts & Things You`ve Done With Yours. #14
Echo, like Stihl, have very restrictive mufflers. It's the noise police at work... Myself as well, don't want any electronic bs. Tractors, saws or whatever. Too bad my car has it but then, at least. cars are pretty reliable. Never fiddled with a Husky so I know zip about them other than Tractor Supply sells them, I see them there all the time.
   / Echo CS-7310P Pro Chainsaw: Questions & Thoughts & Things You`ve Done With Yours. #15
I do like the 'tool less' fuel and oil caps on the Echo's, using the starter handle to unscrew them much better than the Stihl new style caps.
   / Echo CS-7310P Pro Chainsaw: Questions & Thoughts & Things You`ve Done With Yours. #17
When I purchased the aftermarket non cat muffler for my top handle, they waived the shipping cost.
I showed that feature to my brother the other day when he stopped by, he was grinning ear to ear, we BOTH chuckled about that, lol. He mentioned having to use his skrench on his Stihl out in the woods sometimes, and that sometimes he was unable to gets his hands on it, or it was another trip to the truck to get it. So i told my brother, "well, the pull handle is always gonna be with the saw". We even laughed harder about that.
We put the CS-7310 through some hard work yesterday. The saw is fantastic. Ran right through (2ft & 3ft diameter) walnut and oak like a knife through hot butter. We`ve already noticed that the saw is just starting to wake up just after a few tanks of gas. (we run VP fuel in all our saws, 94 octane) If anyone has any doubts about buying an Echo CS-7310, GET IT, it IS a GREAT saw! I`m a hardcore Stihl guy, this saw changed my mind about the Echo brand. When people tell you these saws are BEASTS, they aren`t lying. The saw is VERY well balanced, VERY comfortable to run. Some say they vibrate, i say they should man up. Its a big saw, its gonna have some vibes. As far as i`m concerned, i`ve run much worse saws that would rattle your ancestors teeth out! It isn`t nearly as bad as some may say it is for vibration. I happen to think its the smoothest vibration free saw i`ve ever run, in its class.
Just a added note, we popped the top cover off to see how much debris was in the air cleaner box and filter after a days worth of sawing....... NOTHING! Its was extremely clean! We went through the saw, checked every fastener in the saw, all still tight, not one thing was found wrong or loose anywhere. Very nice saw, we`ll be getting another one and set it up with a skip tooth just for bucking.
   / Echo CS-7310P Pro Chainsaw: Questions & Thoughts & Things You`ve Done With Yours. #20
Good grief ! 73cc's ? Holy cow ! My mini bike was 60cc's and my second bike was 100cc's ! A chainsaw with that much power !
For Sale, Shrink Wrap Kit for implements, tractors, boats etc.
For Sale, Shrink...
2018 JOHN DEERE 323E SKID STEER (A60429)
2018 JOHN DEERE...
Zero Turn Mower (A59231)
Zero Turn Mower...
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
