2023 What HP is the max you can purchase before it is required to have a DEF.
   / 2023 What HP is the max you can purchase before it is required to have a DEF. #1
Fordiesel69
Member
Erie, PA
New Holland Boomer 30
For SCUT's we escaped the DEF requirment back in 2012 and im now curious what the deal is now.
   / 2023 What HP is the max you can purchase before it is required to have a DEF. #2
No one uses DEF below 75hp. The standard does not define the technology, just the limits it needs to reach. I think there are some machines > 75hp that do not use DEF but meet the Tier IV standard.
Between 25.5hp and 75hp the limits are easier. Most machines use EFI and a DPF+DOC but some don't use EFI and some only use a DOC. Below 25.5hp it's easier still and can be met with mechanical injection timing and combustion chamber shape.
Tier IV has not changed since it was mandated. I think there is a Tier V in the works but so far it's just for Europe.
   / 2023 What HP is the max you can purchase before it is required to have a DEF. #3
I think that there was a tier 4 and now were into tier4 "final".🤔
Not that I can tell you the difference between the two or even if I'm correct. 😆
   / 2023 What HP is the max you can purchase before it is required to have a DEF. #4
I was told 75 and up have DEF by my dealer.
   / 2023 What HP is the max you can purchase before it is required to have a DEF. #5
That is correct (for now at least), but all the little ones will still have SCR cannisters and most are common rail HP injection with electronic controls. Why I hang on to my T3 final units. 100% mechanical.
   / 2023 What HP is the max you can purchase before it is required to have a DEF. #6
There was a Tier IV interim starting in 2008. Final was in 2012-2015.
This is a useful chart:
(actually the whole site is useful if you're interested in diesel technology)
PM is Particulate Matter, i.e. soot. Which causes cancer. It's what the DPF and DOC are for. DEF (urea) works with a catalyst to reduce NOx.
   / 2023 What HP is the max you can purchase before it is required to have a DEF. #7
the Deutz 5080D 80/75 hp
-NO DPF Filter and NO DEF Fluid
willy
   / 2023 What HP is the max you can purchase before it is required to have a DEF. #8
SCR is the process by which DEF is used to convert NOX into nitrogen, oxygen, and carbon dioxide. The canister you speak of on <75 hp machines is the DOC, which converts carbon monoxide, hydrocarbons, and some particulate matter into carbon dioxide and water.
2013 Dodge Charger Sedan (A55973)
2013 Dodge Charger...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55315)
JOHN DEERE ROW...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2020 DRAGON ESP...
2003 Big Tex 10PI...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
