Install Winch to Compact tractor
/ Install Winch to Compact tractor #1
BryceSteiner
Antwerp, Ohio
RK25 T25
I'm looking for ideas to attach a 3500 HF winch to my tractor (RK25).
I was wanting to put it on the front but maybe it would be best on the back?
I was thinking permanent on the front somewhere. Removable would be fine for the back. 3-point? Hitch receiver mount? What gauge of wire to bring to the back if that is where and is there a quick connect for DC power?
If you have installed, what would you do different?
I'm looking for thoughts and hints.
/ Install Winch to Compact tractor #3
Agree with Moss, need some clues on how you want to use it.
/ Install Winch to Compact tractor #4
I put a 2500# HF winch on the front of my tractor. I mounted it to the bar where the suitcase weights go (since I don't have suitcase weights). Wired directly to the battery and with a remote control. I've used it to pull my truck up a slippery hill with the tractor acting as an anchor and to pull logs out of the woodlot. It is NOT a forestry winch and HF winches have a very low duty cycle. I rarely use it but it has been very valuable when I did need it.
/ Install Winch to Compact tractor #5
I used this hydraulic winch on my old 3430HST. I made a bracket which would attach to the front frame or the rear drawbar. I powered it with hyd. hoses plugged into the 3rd function valve or a rear remote. I like it since there is no switch or wiring involved. The only drawback is the engine has to be running to use it.
I don't have a need for it much so it mostly sits on the shelf. I have yet to make brackets to attach it to my newer tractors.
mainly to break beaver dams with a homeemade beaver dam breaker. I throw it in the water and pull right now. I'd like to do it remotely.
Also to use pull logs once in a while to trails that I then can carry down with the tractor.
Maybe then if the tractor gets stuck, but I don't plan on that happening anymore.
/ Install Winch to Compact tractor #7
I spose - but doesnt the tractor make a pretty good winch by itself?
/ Install Winch to Compact tractor #8
We have one on a Suzuki samurai, 87 model deer hunting rig. Stock tires and all. Winch does fine.
/ Install Winch to Compact tractor #9
imo winching lets you pull stuff a lot better as ground traction is generally the issue. sheave up a winch a few times and drop the loader or a plough on the back and the tractor will stay pretty much put as opposed to spinning the tires trying to pull in a creeper gear. also look at a hydraulic winch like BDH above mentions. , then you dont need to worrry about duty cycle of the winch or burning out alternators or batteries.
/ Install Winch to Compact tractor #10
Not familiar with your tractor, but some don't have room for a front winch due to the loader crossbar interferring when the loader is in the lowest position, such as digging below ground level.
Bruce
/ Install Winch to Compact tractor #11
Seems like like you could go both front and back with a receiver hitch mounted winch. Also, having a receiver in front is great for backing trailers in tight spaces.
/ Install Winch to Compact tractor #12
See if you could find an older forestry winch that is driven by the PTO. That pull most anything I'd say.
/ Install Winch to Compact tractor #13
Keep in mind most electric winches are designed for intermittent "recovery" use and have large draw on battery and alternator, be sure battery and alternator on tractor are up to the electrical load winch will put on system....
/ Install Winch to Compact tractor #14
This would be the way to go.. RK25 already has a set of rear hydraulic remotes standard. Get a couple lines plumb them in and you are good to go. Now that I see this heck I'm wanting one now... lol
/ Install Winch to Compact tractor #15
Great idea using a hydraulic winch. I’ve been looking at that same model. Would you mount it to the drawbar, or to an attachment off the lower links?
/ Install Winch to Compact tractor #16
I made a mount for mine that hangs on the front weight rail behind the FEL bucket. I power it with the 3rd function valve.
The mount also attaches to the drawbar and I power the winch with a rear remote in that configuration. You never know which way you're going to have to pull.
I bought an earlier model of that same winch and paid a lot more. I'm not sure why the newer version is so much cheaper but it looks identical.
/ Install Winch to Compact tractor #17
I've built my hydraulic winch from scratch and mounted on the front of the tractor. Being hydraulic, I can pretty much use it all day long without worrying about overheating or melting wires.
At the time the idea for the winch came up, I was mowing quite a steep hill (25 to 35 degree) and the idea was to have a recovery winch in case I needed to get out a stuck spot or anything like that.
Turns out, I've never actually had the need for that purpose, but have used the winch in several other uses, from pulling trees when cutting, pulling trees after being cut, pulling my truck out of a muddy mess, pulling big air compressors out of tight spaces for a local company, the list goes on and on.
I used an used hydraulic motor I already had, plus some gears that were given to me from a big milling machine if I recall correctly. I did the math and it's only a 6000 lbs winch but it's still plenty of power for my used. It's quite a bit faster than a commercial recovery winch too.
On my tractor, the front winch is tied with the front subframe of the tractor, which is then tied to mid mounted ROPS that also serve as loader mounts and then it's tied to the rear axle with the lower support bars.
At the time, I wanted to keep the front weights on so I made everything work with the weights. Recently, I did remove the weights and lower the winch quite a bit. I have a thread about the winch build here: Hydraulic winch
/ Install Winch to Compact tractor #18
Yeah, I guess there might be times when I’d need it up front. If I do, I’ll use my 3rd function like you said.
Mostly I see using it as a cheap logging winch to pull logs to the trail so I can skid them back to the yard.
Does the remote lever by your seat control the winch? Or do you pin it open and use controls on the winch itself ?
/ Install Winch to Compact tractor #19
I use the joystick switch to control the 3rd function valve when using the winch on the front. A rear remote valve lever controls it when mounted on the drawbar. I rarely have need to operate the winch when off the tractor. I suppose a remote switch could be rigged if necessary.
Here is what I ended up with. It worked pretty well. I had to make my own bracket. I will be testing it out soon.
I'll have an install video soon of how I did it.
New/Unused Two Wheeled Electric Bike (A61166)
New/Unused Two...
2016 Chevrolet Silverado 1500 Pickup Truck (A61568)
2016 Chevrolet...
UNUSED KJ 3PC WIRE MESH (A62131)
UNUSED KJ 3PC WIRE...
Dad's Garage Decorative Metal Sign (A61569)
Dad's Garage...
2011 FREIGHTLINER M2 CNG DAY CAB (A59909)
2011 FREIGHTLINER...
2013 International WorkStar7400 4x4 Altec AM650 50ft Material Handling Bucket Truck (A61568)
2013 International...
