Is this right?
/ Is this right? #1
txdon
Super Star Member
Central Texas
Kubota M6H-101
I have a Husqvarna 340 chainsaw, about 10 years old. When I fill up the tank the fuel come out the side that is facing down (the side opposite the gas tank). I see a place where a fuel line might be attached but I cannot see a dangling fuel line or where the other side would be attached. I'll try to attach photos.
/ Is this right?
/ Is this right? #3
Could be a fuel line nipple either going to the carb, or a return line from the primer bulb. Need to remove the cover and start checking fuel lines. Should be a line from carb to the tank which would also have the fuel filter on the engine. A line from the carb to the primer bulb, and a line from the primer bulb back to the tank.
/ Is this right?
The nipple shown does not connect to a fuel line, that's what threw me off. The other line next to it was severed at the turn into the housing toward the primer button and I did not see it until I took off the handle and stretched it apart. Replaced it and it works well. Thanks
/ Is this right? #5
Then that would be the one way vent valve to allow air into the tank to prevent vacuum. Sometimes had to tell what is what but I had the suspicion that it could also be the vent valve.
Caterpillar TH255C Forklift (A63688)
Caterpillar TH255C...
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2022 EZ-GO ELITE...
