Now What ?
/ Now What ?
good luck..... luckily it looks like you are not too deep as I can see bottom of your rims on front tires and maybe a little deeper in the back.
If me I would use my 8k electric winch on a F150 with a snatch block and with the tractor in 4wd you should be able to get out. Or my logging winch. A small tow truck would do as well. Hopefully someone not too far from you has similar equipment. I think even another tractor and a good tow strap might work.
Doesn't look like a dozer would be needed.
keeping fingers crossed for you.
Mule, how did you get out of there? Looks like deep mud and tangling brush. Tough walking for anyone, much less for someone that has leg issues.
I fell twice, right after taking the picture. Once forward and once backward. I finally called my Bride and she walked to me and after that I used her shoulders to support me. I stopped often to breathe. When I got to the house I put the oxygen hose in my nose for a while. My heart Dr. says to keep pushing, I am pushing as much as I can.
/ Now What ? #22
It's all you can do; we're all wishing you well, I think I can safely say that.
/ Now What ? #23
Don’t know where you are but if close to East Texas I will load up and come help you. Surely a neighbor that has a tractor would be willing to help. I have pulled several of my neighbors out over the years.
/ Now What ?
You would be a nice neighbor to have, but I would not ask someone to take the chance of getting thorns in their tires. I am about 2 hours away from you. Redwater, Texas. A feller I have known for years is sending two of his hands out, this mornin, to pull me out. They will have a Bobcat.
As fer as my neighbors...no tractors. The two who might, are out of town at this time. In the 47 years that I have lived here my neighbors have changed in every way. The old farm land has been turned into lots and become housing developments. City folks live all around me. My kids will probly do that with my lil-ole 20 acre spot some day soon. I thank it is called "Progress?".
/ Now What ? #25
Progress, indeed. 🤣
Good to see you've got someone helping you out; sometimes we all need to reach out to a friend.
I bet you'll be happy when you can get back on that big red Mahindra.
/ Now What ? #26
That is close enough! If they don’t succeed let me know and I will plan a trip Saturday.
/ Now What ?
Hey, Y'all, It is back at the house. I sure preciate the comforting thought from all. No damage done, as fer as I can tell. They even put the shredder back on, once it got to the house, also. I was told, by their boss to pay what I thought it was worth to me. He said he was just glad to be able to help. I think that was nice of him. I am going to pay $500.00 and know it was worth more.
/ Now What ?
I'm sure your offer will be quite appreciated; having neighbors you can turn to when you're in need, that's priceless.
Good to hear the tractors home! Now, do you have a pressure washer? 🤣
Yes, I have an older Craftsman washer. It is run by a Briggs and Stratton engine. The last time I used it it worked fine. I'll be findin out.
/ Now What ?
OOPS. Due to some sort of mishap the PTO shaft was warped and the shaft rest was bent down as the cutter was being brought out. The feller did not tell me about this he simply attached it back to the tractor. I had driven the tractor out of the woods, he was going to bring the cutter with his skidder and his helper drove my Kubota BX out of the woods. Later in the day I used it to cut a little strip of grass and discovered the major vibration and shaft rest being bent.
I am having the front half of the shaft tube replaced.
I am not upset. Things happen.
I just wish I had been told about it.
A little humor (sorta) about this. The feller who sent his two hands and equipment out is partners with the man who owns the company that is fixing the shaft.
I might be more cautious about getting stuck next time. I blame no one but me. I am thankful it is out and will be back in complete operation after the shaft tube gets in and put back together.
I have always attended the classes with the very best teachers. It is strange that all of the teachers have had the last name, "Experience".
/ Now What ? #32
Just saw this thread and thought I would share that many tow companies do off road recoveries. Usually at least one in your area will have a trackloader with winch to facilitate recoveries like this. My local guy charges $150+ depending on how quickly you need it recovered. He doubles his charge if you want it out right now but if he can get to you when he isn't busy he is very reasonable. Also if you call him direct versus calling the tow company he tows for he gives you a better price.
I found my local guy on youtube who posts videos of some of his more challenging offroad recoveries.
/ Now What ? #33
I have done same ( and worse ). Too often. It means your having a go ! I agree with 2manyrocks that drying out is your best friend. I would have lifted & put logs under the brush hog before disconnect. I have dragged my brush hog 40 feet from dry land as they do skid really well. I have used house jacks to get my tractors up, then railway sleepers under to keep from sinking further. All until conditions improve.
/ Now What ? #34
It’s a small tractor leave the mower hook up and get a wrecker or friend with bigger tractor stay high and dry and pull it out
/ Now What ? #35
Now this unit was stuck 1000+feet from and good ground 8 hours later in the pouring rain had it on dry ground it weighed 100,000#
/ Now What ? #37
Little late to the game as it were. Been where you are and done that.
Thankfully, on the Kubota L4600, I have been able to use the bucket to back out. The biggest issue I have is loading up the tires to generally replicate a balloon so there is no traction. If the back tires start to sink, I generally catch it early and STOP! Rotary cutter (Bush Hog) weight makes things a lot worse in conditions like this.
/ Now What ? #38
Mule,
Seeing as you've told us where you live, it's obvious you have no objections to fellow members knowing. It would be helpful to curious people like me if you listed your approximate location and your tractor under your name to the left. With a problem like yours among my first thoughts are what part of the country has enough rain to get him stuck at this time of year, is he in sand that will drain quickly or slick slippery clay, things like that. If you were near enough there is also the possibility that I might go over and try to help.
I hope you're already unstuck and admire you for fighting back against your health problems.
/ Now What ? #39
Now something helpful. Chain to the bucket curled down then curl to inch forward. Come along can be use as well, the hydraulics are way stronger than me. In you case you will want someone to do the rigging until it is out. I'm lucky my kid lives here....
A chain shortener, double grab hooks on short chain comes in real handy about then as well.
Agree with exploring this approach...neighbor got his old Massey-Ferguson stuck at the bottom of a hill, where the soft mud and slick grass live. He slowly worked it out using the bucket to raise the front out of the ruts and curl forward.
/ Now What ? #40
Having a general location also helps when people like myself wonder if we are close enough to help pull someone out.
I get listing a general "East Texas" or "Central Oklahoma" location to cut down on scammers' information gathering. If you need to know where I live more precisely, shoot me a PM!
1991 FREIGHTLINER FLA-89 T/A SLEEPER TRUCK TRACTOR (CABOVER) (A67148)
1991 FREIGHTLINER...
2017 Caterpillar DP70N1 15,500lb. Straight Mast Diesel Forklift (A64194)
2017 Caterpillar...
2015 Nissan Altima Sedan (A64557)
2015 Nissan Altima...
2025 Precisions Provencal 22ft. 5th wheel Mobile Office/ Showroom Trailer (A64556)
2025 Precisions...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
