Kubota 3910 ran out of water and will not run
   / Kubota 3910 ran out of water and will not run #51
I have not seen anything in this thread to suggest the OP's neighbor has a bad water pump. Someone else told a side story about his aging father's tractor with a dripping water pump. I think you have that and the OP situation confused.
no I am not and he will … water pump can’t run dry and if it turns for extended period of time without water it will overheat and melt the seals and compromise the bearing … so after the engin issues get figured out mine as well to be prepared to rebuilt the water pump.
   / Kubota 3910 ran out of water and will not run #52
The water pump, if it is bad as you predict, is by far the least of the OP's neighbor's worries.
   / Kubota 3910 ran out of water and will not run #53
They can blow up pretty quickly if run dry … I am just pointing out one more thing to check or take account of … I also said it won’t be his priority obviously he has to figure out the extent of the engin damages fist but i would hate to see the engine fix without looking at the water pump and blowing the engine for good or again …
   / Kubota 3910 ran out of water and will not run #54
In reality water with no AF added is a better conductor of heat.
yes concentrate AF is not good ... since on the subject of Antifreeze I just learn about diesel Antifreeze and its added additives to reduce cavitation... I was not aware of this. Initially when I got told I though it was a joke so I researching it and its true ... Not sure how important it is but worth knowing for sure.
   / Kubota 3910 ran out of water and will not run #55
Only applies to a wet linered diesel engine. Parent bore or dry liners where the coolant don't touch the liner don't count and most cavitation supplements are additives, not in the AF. I use DCA4 myself.
   / Kubota 3910 ran out of water and will not run #56
If I understand correctly it depends whether or not there is cooling cavity (bore) directly around the piston cylinder or not and these cavitation (bubbles) happens in these location ? ... the owner manual must specified whether or not these additives are required for each engine ?
but you can buy AF with the additive already in because some specified diesels engine AF and are more expensive then the traditional ones ... but yourself use normal AF and add the additive using DCA4 afterwards ?
   / Kubota 3910 ran out of water and will not run #57
I add DCA4 with the antifreeze and I test the PH of the coolant regularly with a Fleet Guard PH test kit and if the PH isn't within the specified range, I add additional DCA4, which is a buffered solution to the coolant to bring it within the required range. Other nice thing about DCA4 is even in a parent bore (dry liner) engine, keeping the PH within specified range means your cooling system and radiator don't get internally clogged.
My Kubota's both run conventional ethylene glycol (green) coolant but I'll add DCA4 to them to keep the PH within the required range. I only own one wet linered engine and that is the 3406 Cat diesel in my farm truck. I change the coolant in both my Kubota's every other year anyway.
DCA4 is available online or at most any truck dealership's parts counter. It's a Cummins part but is used in all heavy duty diesel engines.
The Fleet Gard PH test kit isn't a cheap date but is a requirement for me. You can also use a Brix Refractometer to ascertain the PH level if you want to go that route.
One thing you NEVER want to do is mix extended life coolant with conventional ethylene glycol as it will turn to goo inside the engine.
   / Kubota 3910 ran out of water and will not run #58
That is correct. if the liners are exposed DIRECTLY to the coolant (wet linered engine), then cavitation can occur and once it starts it keeps right on going until the liner gets a hole in it and then it's rebuild time. Like I said, I still use it (DCA4) to keep the PH of the coolant withing the required range because it prevents things like solder bloom inside the radiators and keeps the coolant passages in the engines clean as well.
Coolant wears out and the additives decrease with each heat and cool cycle.
   / Kubota 3910 ran out of water and will not run #59
You are right on the coolant 5030, but cavitation can happen in all diesels. The thin liners are most susceptible to cavitation erosion, but so are the blocks of engines without liners. The international 6.9 and 7.3 engines (IDI and PS) are know to spring leaks if the coolant is neglected.
Don't know where the OP went, but I'm curious is the owner is going to fix or scrap the tractor. I wonder what a long block for it would even cost?
   / Kubota 3910 ran out of water and will not run #60
I know and I own a 7.3 PS and it gets DCA4 and it's PH checked regularly. In fact Fords recommends it in the owners manual (which I have) as I bought the truck new in '97.
10' Container W/Side Door and Window (A57149)
10' Container...
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
CFG Industry QK16R Mini Excavator (A57149)
CFG Industry QK16R...
2124 (A58376)
2124 (A58376)
2014 Dodge Charger Passenger Car, VIN # 2C3CDXAT8EH223963 (A57453)
2014 Dodge Charger...
