recommendations on good, quality fertilizer spreader for residential use
   / recommendations on good, quality fertilizer spreader for residential use #1
tstex
Alleyton, Texas; Houston, TX
1997 Kubota M5400S
Hello to all
  • Looking or a solid recommendation on quality fertilizer spreader for yard use/residential.
  • Can be either single or dual action.
  • Mainly for fertilizers of various types that has a good calibration system for
    • both RIGHT application amount
    • and CORRECT & EVEN distribution of product.
  • Would like it solidly made w brass type nuts/screws/etc so it will not corrode quickly.
Will wash after each application and oil accordingly.
On the way to buy in an hour or so..thank you
Thank you very much,
tstex
   / recommendations on good, quality fertilizer spreader for residential use #2
I have one of these I use.
The good. You can raise and lower the 3 point to control how wide the pattern is. You can also throttle up or down to throw the fertilizer wider. You can vary your ground speed to vary the density of the fertilizer. It also hold a lot, maybe a couple hundred pounds or more. The gates have a lot of adjustment also to control the rate.
The bad. All those different ways to control things make it hard if you are after the perfect rate. I usually apply a low rate and apply it lightly to get everything covered.
Thanks, but this is inside a residential yard that cannot be accessed by any type of tractor or similar. has to be a push spreader...
   / recommendations on good, quality fertilizer spreader for residential use #5
I've had several years' use out of an Earthway spreader.......It is still in good shape having spread many bags of fertilizer and some lime. Depending on how hardy I feel, I load it to the level that I can push it at a steady rate of walking.
Cheers,
Mike
Thank you guys...on the shoulder or carry spreaders, good if a very small area and the fertilizer does not have powder in it and it's not a windy day. Getting blow-back dust in the face isnt preferred....thanks again
   / recommendations on good, quality fertilizer spreader for residential use #7
I have the Earthway in the link below. About 12 years old and still looks and works like new. Liked that it has adjustable handles(I’m 6’3”) and stainless hardware. It’s very pricey now. There is a residential model for significantly less, not sure of the details
   / recommendations on good, quality fertilizer spreader for residential use #8
   / recommendations on good, quality fertilizer spreader for residential use #10
There is a better one out there. I used this for decades and finally wore it out...it worked but no game changer.
In visiting my local primarily used equipment dealer he had a different brand with no manufacturer tag to be found. Difference was SS slinger, slide distribution selector under the front of the unit...easy to select, and convenient hold/dump adjustable lever.
The cone was light weight high tensile steel making the moving and mounting much easier. I bought it a couple of years ago, works great and was under $500 for 4-500# capacity...same as the one pictued.
2012 CATERPILLAR 305DCR EXCAVATOR (A52707)
2012 CATERPILLAR...
BOMAG BW75AD WALK BEHIND SMOOTH DBL DRUM ROLLER (A52707)
BOMAG BW75AD WALK...
2004 AGCO Gleaner 3000 Corn Header (A57024)
2004 AGCO Gleaner...
2021 CATERPILLAR 226D3 SKID STEER (A52707)
2021 CATERPILLAR...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A54811)
2019 Caterpillar...
