How to paint raised lettering on tractor
   / How to paint raised lettering on tractor #1
krogers
Member
ford jubilee
Have any of you learned a good way to paint the raised lettering on tractor body work? I have been trying to find a way to do this on my Ford Jubilee. I tried using a sponge with paint on it by lightly pressing onto the letters but that did not work. I see decals advertised. I will research if that would be an alterative. Thanks.
   / How to paint raised lettering on tractor #3
You might try this.
Apply grease to the lettering - then using a firm sponge with an absorbent cloth, wipe the grease off the letter surface you are wanting to paint (spray). Wipe with a solvent also to remove grease before painting. Spray the letters and let dry - then remove the rest of the grease. I used to do this for parts of a car when I spray painted the car.
The decals sound good also.
   / How to paint raised lettering on tractor #4
Or tape over the entire area & cut out the letters from the tape shield with a razor knife.
   / How to paint raised lettering on tractor #5
All my life I've been curious how Ford did it at the factory?
   / How to paint raised lettering on tractor #6
I think they also sell a spray "blocking" that dries to the consistency of contact cement or light rubber. Spray off the area & cut out the letters to make a temporary stencil. then remove the rest when done.
or
   / How to paint raised lettering on tractor #7
Painted letters with a brush. I had old tractors with brush marks. You could tell as it was fading away. Just paint hood or whatever, paint raised area with a brush. Easy.
   / How to paint raised lettering on tractor #8
I used a foam roller, still needed a rag with thinner to clean some areas.
David
   / How to paint raised lettering on tractor #9
Interesting replies. (y)
   / How to paint raised lettering on tractor #10
2008 CATERPILLAR 12M MOTOR GRADER (A51406)
2008 CATERPILLAR...
2012 Freightliner (A53314)
2012 Freightliner...
2014 Mack CXU613 Truck, VIN # 1M1AW02Y6EM040637 (A54865)
2014 Mack CXU613...
2022 Padget Morris Electric Mobility Scooter (A55853)
2022 Padget Morris...
2019 Vermeer RTX 250 48in. Walk Behind Trencher (A55787)
2019 Vermeer RTX...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
