pt1430 wont go forward or backward basically stuck in front yard
   / pt1430 wont go forward or backward basically stuck in front yard #21
Here is instructions from my 1430 manual on the tow procedure. I wish they would proof read their manual, or is it me? (or the "if equipped" disclaimer"). It says to loosen the fitting 2 turns, but then it describes installing a supplied hose. My machines never came with a hose. And other hydo drive machines I have just turn that valve to free wheel.
Anyway the point I tried to make a few post back, was to make sure that "tow valve" didn't back off the 2-turns and now disable your drive.
i called terry back and i described the tram motor and he said since i my tredle is hydraulic i didnt need a jumper hose. he said turn the bolt head (barely seen above and to the right of the 3/16 lettering on hose) anywhere from 1/2 to 2 turns and he said that should free up the wheels so i can get it towed back up to the garage so i can get it out of the front yard and start working on getting the tram motor out. he said when i get it in the garage, i should either remove the gas tank or swing it out of the way, disconnect the pto/steering pump from the tram pump, label all the hoses and then disconnect the hoses then disconnect the tram pump from the engine. so more to come when i do get it back in the garage.
   / pt1430 wont go forward or backward basically stuck in front yard #23
X2 on the "label the hoses" advice! Preferably labeled in more than one place with materials that are oil resistant. (BTDT...) I have found that taking lots of photos as I work my way along to be really helpful in the reassembly process.
Congratulations, it seems like you are making progress.
All the best,
Peter
   / pt1430 wont go forward or backward basically stuck in front yard #24
Good. I wish mine had a tow port.
As mentioned, labels and pictures, pictures and labels. Oily hoses tend to shed taped labels.
I'd give everything a really good degreasing and bath before attempting any disassembly. Dirt is the enemy of hydraulics.
Good luck and thanks for the update. (y)
   / pt1430 wont go forward or backward basically stuck in front yard #25
My tractor is probably dirtier than yours (drought, dust, and hard water here), but I wash everything first in Dawn and water, the compressed air, then brake cleaner, and I scrub the fittings with a toothbrush and brake cleaner one last time to get the dirt out of the threads. I have learned the hard way to wash a bigger area than I need to just to not fingerprint dirt in from some nearby area of the tractor.
When I asked how clean does it need to be to open a motor hose, Terry's advice to me was along the lines of "clean enough for open heart surgery...":)
All the best,
Peter
   / pt1430 wont go forward or backward basically stuck in front yard #26
X4 with wash the area as best you can, label, picture, draw and document where hoses connect.
It may look clean now, but after a month of waiting for the part to come back, it will look like a tangled mess of old Christmas lights.
   / pt1430 wont go forward or backward basically stuck in front yard #27
I used zip ties of various colors on the hydraulic lines then sketched the ports with the corresponding colors to when I swapped my pump.
thanks everyone, i had a local farmer get the pt towed up to the garage today. i got the hoses ziptied with different colored and sized zipties so far. stiil have to unscrew the big hydraulic filter housing from the gas tank and also have to remove the battery so i can get the gas tank moved so i can get to the tram pump. ill give everything a good cleaning once thats done then take more pics for documentation before taking off the pto/sterring pump to get to the tram pump. after 16 years of owning this 1430 finally a major problem to really take a lot of time to get it fixed. also someone asked how many hours i have on it and i have a little bit above 900 hours. thanks
   / pt1430 wont go forward or backward basically stuck in front yard #29
You might want to try not taking the hoses off the PTO pump, if it can just be moved out of the way enough to get the tram out.
The worse part of this job is the oily mess.
Be careful on how much it weighs, might be close to 50 lbs or ?
   / pt1430 wont go forward or backward basically stuck in front yard #30
You know, that color coded zip tie deal is pretty slick! (y)
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A59905)
2018 INTERNATIONAL...
2005 FREIGHTLINER WESTERN STAR DUMP TRUCK (A60430)
2005 FREIGHTLINER...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
2020 KENWORTH T680 SLEEPER (A59904)
2020 KENWORTH T680...
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
2017 Ford F-550 Service Truck (A59230)
2017 Ford F-550...
