Question on 2305 John Deere
/ Question on 2305 John Deere #1
Tre4
2006. 2305 John Deere
Got plastic bag sucked in engine can I remove head on my 2305 without disassembling head already have valve cover and manifold off
/ Question on 2305 John Deere #2
Welcome to TBN
To better understand where the plastic bag is at, can you give some more details? Was it a light-weight grocery bag? Where was it sucked in? Can you see any of it? Was the engine up to running temp when it happened? Will the engine turn over or is it locked up? Any other details?
/ Question on 2305 John Deere #3
If it's not in the manifold, yes, you have to pull the head. But what we all want to know is how is this possible? Were you operating without an air cleaner?
/ Question on 2305 John Deere #4
The only way this happens is if you have no air filter installed. The plastic bag is then not your only issue?
/ Question on 2305 John Deere #5
What size plastic bag?
What a fascinating subject. Would a small plastic bag create a problem if it gets sucked through? Wouldn't it be shredded up, burned and expelled?
This the the OP's first post. It's likely that we will never hear from him again.
/ Question on 2305 John Deere #6
+1. I'd bet that if it's past the intake, it's already through the motor and burning up inside the muffler. Now, how did this happen???
I found a food store plastic bag jammed into my daughter's furnace blower housing, just a few weeks ago. I'm thinking it got in through an open kitchen cold air return, then dislodged from the filter as I pulled it out to replace the filter. I'm glad I pulled the furnace cover off, so I could glance in there...
DURA-CAST PRO-LICK TANK (A62131)
DURA-CAST PRO-LICK...
2019 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2019 PETERBILT 579...
211317 (A62129)
211317 (A62129)
2020 INTERNATIONAL LT625 48" SLEEPER (A62613)
2020 INTERNATIONAL...
Kuhn FC400RG (A60462)
2020 Westfield MKX 100-83 Auger with Swing Hopper (A61307)
2020 Westfield MKX...
