Bending square u-bolts with shop press
   / Bending square u-bolts with shop press #1
TimBuck2
Central Massachusetts
Kubota L4310 HST and Ford 841
I am refurbishing an old Cox boat trailer and have been searching and searching for the correct size square u-bolts to fit various applications. I have decided it's impossible to find something you can live with, never mind finding a size you want.
Has anyone fabricated a "die" set up for their shop press that does a decent job of bending square u-bolts?
Seems like it should be pretty straightforward ...
Thanks,
Tim
   / Bending square u-bolts with shop press #2
I wouldn't do that on a boat trailer. Too much liability. Same reason most welders won't weld anything on a hitch.
Too many variables like stress fractures, crystalline structure, work hardening, just to name a few.
Have you tried contacting a Cox dealer for the correct part?
   / Bending square u-bolts with shop press #3
Some marine supply houses have boat trailer parts...
   / Bending square u-bolts with shop press #5
I haven't done this for axles, but other places I've replaced U-bolts with a heavy strap and two standard bolts. Probably stronger than DIY U-bolts.
Bruce
   / Bending square u-bolts with shop press #6
Most boat trailer u-bolts are galvanized after they are bent...
   / Bending square u-bolts with shop press #7
For most any hardware, the answer is almost ALWAYS McMaster-Carr...
   / Bending square u-bolts with shop press #8
   / Bending square u-bolts with shop press #9
You'd be better off drilling flat steel stock and using bolts and nuts than trying to bend your own. As MB hints, bending All-Tread never ends well.
   / Bending square u-bolts with shop press #10
Could you just use an upper plate and a lower plate with two regular bolts?
INDUSTRIAS AMERICA F12T HYD TILT LAND LEVELER (A51406)
INDUSTRIAS AMERICA...
CARONI 6' FINISH MOWER (A52708)
CARONI 6' FINISH...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52709)
KNOW BEFORE YOU...
2018 MACK CHU613 DAYCAB (A58214)
2018 MACK CHU613...
2007 Pierce Dash Pumper Fire Truck (A55973)
2007 Pierce Dash...
TIRE & RIM, SKID STEER PLATE, MISC HITCHES & PARTS (A52708)
TIRE & RIM, SKID...
