Bending square u-bolts with shop press
   / Bending square u-bolts with shop press #1
TimBuck2
Central Massachusetts
Kubota L4310 HST and Ford 841
I am refurbishing an old Cox boat trailer and have been searching and searching for the correct size square u-bolts to fit various applications. I have decided it's impossible to find something you can live with, never mind finding a size you want.
Has anyone fabricated a "die" set up for their shop press that does a decent job of bending square u-bolts?
Seems like it should be pretty straightforward ...
Thanks,
Tim
   / Bending square u-bolts with shop press #2
I wouldn't do that on a boat trailer. Too much liability. Same reason most welders won't weld anything on a hitch.
Too many variables like stress fractures, crystalline structure, work hardening, just to name a few.
Have you tried contacting a Cox dealer for the correct part?
   / Bending square u-bolts with shop press #3
Some marine supply houses have boat trailer parts...
   / Bending square u-bolts with shop press #5
I haven't done this for axles, but other places I've replaced U-bolts with a heavy strap and two standard bolts. Probably stronger than DIY U-bolts.
Bruce
   / Bending square u-bolts with shop press #6
Most boat trailer u-bolts are galvanized after they are bent...
   / Bending square u-bolts with shop press #7
For most any hardware, the answer is almost ALWAYS McMaster-Carr...
   / Bending square u-bolts with shop press #8
   / Bending square u-bolts with shop press #9
You'd be better off drilling flat steel stock and using bolts and nuts than trying to bend your own. As MB hints, bending All-Tread never ends well.
   / Bending square u-bolts with shop press #10
Could you just use an upper plate and a lower plate with two regular bolts?
WHIRLPOOL DRYER (A54757)
WHIRLPOOL DRYER...
2000 Volvo VNL Sleeper Cab Truck, VIN # 4V4N21JF6YN250211 (A57453)
2000 Volvo VNL...
2015 Volkswagen Jetta Sedan (A55758)
2015 Volkswagen...
NEW Wolverine Skid Steer Trencher (A59000)
NEW Wolverine Skid...
Hustler super Z zero turn (A56859)
Hustler super Z...
2015 DRAGON 130 BBL VACUUM TRAILER (A58214)
2015 DRAGON 130...
