MF 231S Priming Pump leak
/ MF 231S Priming Pump leak #1
fireman4074
MF 231S
My MF 231S is leaking diesel from the priming pump when running. It is coming out of small hole on the side. It is had to tell from the pictures. I wish that it was some type of way to upload a video. It just start this today. It will run fine and I can do whatever I need to do with it. I just want to get it fix before something bad happen. Have anyone else had this problem? If so, what can I do to fix mine?
/ MF 231S Priming Pump leak #2
That hole is there for a reason.. to tell u it getting ready to dump fuel into the oil or drain your tank of precious diesel fuel..
Replace it..
Replace it..
Is it as simple as taking old one out and putting new one in? Or do cam have to be in certain position?
/ MF 231S Priming Pump leak #5
Looks like the only thing that needs to be done is replace the fuel lift pump. Very simple, and cheap fix. If I can do it, anybody can do it.
Fuel Storage Tank (A68134)
Fuel Storage Tank...
JOHN DEERE 300P EXCAVATOR (A65053)
JOHN DEERE 300P...
2014 CATERPILLAR 320EL RR EXCAVATOR (A65056)
2014 CATERPILLAR...
OUTBOARD ENGINE STANDS (A66738)
OUTBOARD ENGINE...
2010 Dodge Charger Sedan (A66738)
2010 Dodge Charger...
2017 CATERPILLAR 950GC WHEEL LOADER (A64279)
2017 CATERPILLAR...
