paulsharvey
Super Member
I dont like #57 stone for a parking area. It never really firms up, and is an added expense. Only way #57 really firms up, is to be pushed into finer material.
Material vary a Lot area to area, but I would strip organics/top soil; add clean fill to about 6" below final grade; you choice/$$$ of asphalt millings, crushed roadbase, or crushed concrete (not gravel, from fines upto rocks, so that the diffent aggregate grades lock together). If it's an erosion prone area, prime with asphalt prime and spread granite screens. Boom, done for 15 years. Crushed concrete is and will always be dusty, but water doesn't bother it. Limerock road base gets a nice 'seal' on the top, but fines will get muddy, and/or erode. Millings aren't very dusty, resist water/erosion well, and does somewhat lock together. Don't belive the myth that the summer heat will melt it back into asphalt, that doesn't happen.
Parking Pad implies wheel turning, and a pure 57 stone will get loosened up by all that turn.
An cheap option would be 6" of sand-clay, topped with less finish material, maybe 3".
Edit: ball field clay, not a fat gumbo with a bit of sand...
Geofabric increases the time to see problems with the subgrade, but it doesn't actually prevent it. Better to address the root cause, unless it's bottomless muck.
