New to me Ford 2810
/ New to me Ford 2810 #1
PM Wells
Foothills Of The Blue Ridge NC
98 New Holland 3930-- 95 Massey Ferguson mf 253
Just bought a Ford 2810 tractor that is in reasonable good original condition. Brakes need adjusting, pedals go pretty much all the way down, but will stop the tractor. Need some advice on adjustment. Thanks
/ New to me Ford 2810 #2
Congratulations on getting a Ford 2810! The 10 Series Ford's, in my opinion, are some of the best tractors ever made. We have a 4610 that is still a workhorse on our ranch.
I haven't adjusted brakes on ours but I think you just shorten the linkage to account for wear. Jack one tire up, shorten the linkage and have somone push on the pedal, until you can just barely move the wheel then back off a turn or two so there is no resistance. Repeat on the other side. Then check to make sure that when you stop, that brakes do not pull to one side. If they do redo the side that the tractor pulls to. It's a trial and error process.
That makes sense, guess I am used to the drum brakes. I did look it over today, and can see the adjuster linkage, thanks for your help. I had a 2810 in the mid nineties that was in new like condition, never had to do anything to it, so didn't learn anything about working on it. Thanks again.
Ok brake adjustment turned out to be a piece of cake. Loosened the lock nut and took up about 1/8 in of the threads and have good pedal now on both sides, tighten lock nut, drive around checking each brake pedal to make sure it is not grabbing on either side.
I really like these Ford tractors, this is the second 2810 I have had, had 3 3930s and one 3910, for me they are some of the best tractors ever made. This 2810 was a two owner, it is a 89 model, the first owner having it about 20 yrs. It has 1566 hrs on a working tach, and is in really good condition, it will need rear tires before too long. really satisfied with it.
Hydraulic fluid recomendation for the Ford 2810, prices from 44.95 5 gal. to 146.00 for 5 gal 134b and 134c I know normally you get what you pay for, but are some of the cheaper fluids as good as the higher priced fluids
/ New to me Ford 2810 #8
Congrats on the brake adjustment.
If the fluids meet the Ford M2C134X spec for your tractor, then you're good to go. The NH Ambra is pretty expensive and if you have a Costco near you, they carry (at least in my area) a premium transhydraulic fluid that meets the Ford spec. Most of these fluids are in the range of $65 to $90 for a 5 gallon pail. You might want to consider replacing the hydraulic filter also.
I did find a brand at Tractor Supply that did meet the Ford New Holland spec M2C 134 ABCD for 60.00 five gals. So ready to go with new filter and oil / fluid The tractor has 1566hr on it and I believe changing the fluid is about 1200 hr Thanks for the help
Anyone have a front end loader for sale that would fit this ford 2810 tractor?
Harlo HP6500 (A60462)
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
PICKUP TOOLBOX (A58214)
PICKUP TOOLBOX...
2015 JLG Skytrack 8042 (A60462)
2015 JLG Skytrack...
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
CFG Industrial H15R (A60463)
CFG Industrial...
