Fuel Cap
/ Fuel Cap #1
Raccroc
Branson 3520R
Anyone know of a universal fuel cap that will fit on a Branson (specifically - 3520R)?
While disking, mine came came off and cannot be found. Unfortunately, my local dealers and all the onlines one I have been able to fine are out of stock. I cannot wait the weeks it might take to get an OEM replacement from one of them and need something I can get right now.
Anyone know of a fuel cap that will work? Doesn't have to be great, just get me through the next few weeks or so.
/ Fuel Cap #2
BE VERY CAREFUL, the 15/20 series use the cap as the tank vent so which ever you end up using needs to have a vent built into it.
/ Fuel Cap #3
Zip loc bag and a rubber band. Put a little stick vertical to let it vent. Ran them for years that way. You can get fancy and use a hose clamp. You can buy a pipe test plug at a hardware store. It's a rubber cap with a hose clamp on it. Used for head pressure on drain lines. I have them to repair radiators, so I can pressure them up and make sure no leaks.
/ Fuel Cap #4
Not to question your knowledge of Bransons, you have frequently offered very worthwhile insight; but is it indeed a vented cap? I ask this because my 4720ch has vent lines running from each of the tank halves to a point by the upper link on the three point. This vent line clogged once and my tractor was acting as if it were running out of fuel when it wasn't. I ran a wire down it, blew it out with air cut off a few inches and based on LouNY's suggestion, installed a fuel filter to keep bugs or whatever it was getting in the vent line. It has worked fine ever since. Perhaps I have a vented cap that is also clogged and there is a redundant vent system?
/ Fuel Cap #5
That's probably because yours is an older model with the dual tanks.
I can indeed confirm that the newer models(newer than your tractor), with the single tanks vents through the cap. Mine is that way.
/ Fuel Cap #6
aah you beat me to it ptsg, yes i should have been more specific, the new i believe 2014-2015 & up will have the newer caps with the vents and anything before that year range should have the dual tanks with built in vents
/ Fuel Cap
Thanks for the advice and info everyone!
(1) New 7ft Chain Sling (A65579)
(1) New 7ft Chain...
New/Unused Quick Attach Landhonor Hydraulic Winch (A65583)
New/Unused Quick...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
John Deere X500 Riding Lawn Mower (A66285)
John Deere X500...
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
Lot of (15) Hedge / Black Locust Posts (A66408)
Lot of (15) Hedge...
