another hiccup to going solar?
   / another hiccup to going solar? #51
Lowest demand during the day? I thought it was later at night, like when everybody is sleeping.
EVs are draining the grid at night.
   / another hiccup to going solar? #52
Ok.....maybe not lowest....but lower.
Most residential households use the most electric from about 6p-10p. Thats when everyone is home....cooking, TV, laundry, showers/hot water, lights, cranking up the thermostat if you set it back in the morning...etc.
However.....thats when residential solar output is starting to sharply decline for the evening down to nil when the sun sets.
Thats the point I was making
   / another hiccup to going solar? #53
I don't see why utility couldn't pay a person for power and pay the going rate, whatever that is at the moment. They do that now, look at Texas. They have a number of providers and a person buys power from them. They don't have to care how expensive it is for you to produce, if you price it too high they don't buy it.
I have no issue with this.
However.....for the past 10 years ALOT of utilities have done 100% net metering. meaning if you use 2000kwh and make 2000kwh, their bill is $0......OR if they use 2000 and make 1000, they are only paying as if they used 1000.
Meaning that whatever electric was consumed.....they are getting FULL RETAIL PRICE as a credit and NOT at a WHOLESALE rate.
At a wholesale rate for generation of power.....(In my area thats about 50% of the bill).....If I used 2000 and made 2000....that should NOT be a $0 bill. Rather a bill at about 50% a normal bill. And that remaining 50%.....even though I generated as much as I used.....Is my charge for using the infrastructure of the grid as my battery
   / another hiccup to going solar? #54
Power availability at night goes down for other reasons: peaking plants shutdown,
not importing purchased power from afar...
EVs could be a resource to redistribute power during necessary times.
R
   / another hiccup to going solar? #55
From the cost benefit side of solar, California's new policy will kill home solar. We had whole house solar in a large home in NW Washington. With full net metering, going solar was only marginally profitable. The payoff came at 15 to 20 years, allowing about 10 to 15 years before the solar panels needed replacing. When the panels need replacing, no doubt some of the power interface will have to be replaced also, winding the clock for effectively paying for solar power for another 10 to 15 years. Reduce the benefit by 80% and there is no economic benefit to home solar. Throw in the cost of batteries and the room set aside for them, and the shorter life of batteries, there isn't going to be much incentive in trading a utility bill for a solar panel/battery payment.
Where I moved to, the electricity is provided by a county PUD at about 60% cost per KWH of the previous home, so the decision is to not go solar.
   / another hiccup to going solar? #56
I’m in SCE (SoCal). Here are the current rates for Time of Use. Yes, they are paying me $.35 for the time I am generating, BUT they charge me $.50 for my high use time. I hardly believe that they are losing money at these rate. The vast amount of my bill is during their gouge time. Give a little, take a LOT!
   / another hiccup to going solar? #57
At a wholesale rate for generation of power.....(In my area thats about 50% of the bill).....If I used 2000 and made 2000....that should NOT be a $0 bill. Rather a bill at about 50% a normal bill. And that remaining 50%.....even though I generated as much as I used.....Is my charge for using the infrastructure of the grid as my batteryO in this equation
There should be other things in the equation:
Does the solar or wind producer have to support the executive and shareholders (over)compensation?
Does the alternative energy producer get to sell the REC's that are produced? (Renewable Energy Credits) Many car makers sell EVs at a loss
to utilize these.
Are the utilities and their in-place lobbyists and legal teams the ones to set the reimbursements?
A more equitable path should prevail.
I is nearly a quarter of the way into the 21st century, the horse and buggy whip industries should be allowing for change.
regards,
R
   / another hiccup to going solar? #58
Wow .....
Residential
Service availability $1.018 per day + Energy charge 9.15 cents per kilowatt-hour plus a $20 membership/meter charge per month.
Comes out to around 11.2 cents per kwh on average.
No time of use rates
   / another hiccup to going solar? #60
As far as I'm concerned, utilities should be paying homeowners and businesses to install panels and wind turbines to help provide power rather than funding huge industrial generation facilities or funding them with government incentives. Or at least installing their own on customer provided land and rooftops. Work out deals like Cell towers ... provide the equipment and maintenance with a service exchange incentive.
The business model has to begin to change.
I can tell from reading this and more of your post that you’ve never ran a business or worked in a position that dealt with business decisions. They’re still going to need the industrial generation sites and they’re still going to need adequate capacity to handle the grid. You can throw billions of dollars at solar and wind farms. It doesn’t help the fact that solar is limited to sunny conditions and wind isn’t reliable either. Why wouldn’t they just put the money towards the industrial plants that they still need? If you have a solution that would actually work to eliminate the need for the industrial plants I’m sure they would love to hear it but currently that doesn’t exist especially at a reasonable price.
1998 CATERPILLAR 953C CRAWLER LOADER (A52707)
1998 CATERPILLAR...
2003 McCormick XTX 185 XtraSpeed Tractor (A57024)
2003 McCormick XTX...
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
Nissan CF60 6,000lb LP Forklift (A55851)
Nissan CF60...
SKID STEER FORKS (A53843)
SKID STEER FORKS...
2002 Wacker RD11A Tandem Smooth Drum Roller (A54811)
2002 Wacker RD11A...
