Changing Grammer seat to tip-up option
/ Changing Grammer seat to tip-up option #1
koolken
Member
Elie
John Deere
Hoping i can get some help. I neeeed a new seat and planning on buying this seat but it says i loose the ability to operate pto when off the seat. Has someone rewired or changed something so i can get off the seat cause running pto while off the seat is a must have option for me.It says...
Please Note: This seat and suspension kit mounts down solid to the tractor and is not designed to tip forward. Customer will lose the ability to tip seat forward and also the ability to run PTO while the seat is tipped forward and off the tractor, unless other measures are taken, which are the buyer's responsibility if they wish to keep this feature.
/ Changing Grammer seat to tip-up option #2
I have an L47 which is a little bit different but I'd bet the sensor is the same. There's a pressure switch mounted to the bottom of the seat. I just wrapped a zip tie around the plunger of the sensor and now PTO always works.
/ Changing Grammer seat to tip-up option #3
I did that on my old L3200 fine. Easy to reverse. Trivial on the flip up spring seat. I've never been bothered to mess with it on the L4060 with air ride. If i do end up needing the PTO generator, it will be a few rocks in the seat I expect. Havent needed it in 5 years though.
Sensors are usually 3 wires. More work than just cutting or shorting a wire. 1 normally open, 1 normally closed & 1 power wire. Not hard to install a bypass or bypass switch if you are motivated.
I am motivated to do whatever it takes. I need a seat as my suspension is broke and the seat is torn so a upgrade is a must. Also wondering if I bypass that switch will that also bypass the footpedal or is that a different switch?
/ Changing Grammer seat to tip-up option #5
The sensor is 3 wire so it can register somebody seated as well as seat flipped up. Seated includes HST pedal in the safety loop. Seat up doesn't.
Soo your saying if i bypass the seat safety switch permanently it will not effect the HST pedal?
/ Changing Grammer seat to tip-up option #7
If you just zip tie the seat sensor, the HST sensor still works. You can electrically bypass the seat sensor, but it's a bit more complex. Generally you need to make sure 1 wire is jumped to the hot wire & make sure the other is disconnected.
Ok that's what i needed to know. Thanx for the information...i appreciate it!
/ Changing Grammer seat to tip-up option #9
Lots of probably in my statements. Verify with a multimeter before you try to rewire anything.
Redirective Crash Cushion Guardrail (A59230)
Redirective Crash...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
2008 Chevrolet C7500 Altec TA40 41ft. Bucket Truck (A59230)
2008 Chevrolet...
2019 Ford F-150XL (A60462)
2019 Ford F-150XL...
2006 GEA Westfalia Separator CA 501-00-32 Two-Phase Decanter Centrifuge (A59228)
2006 GEA Westfalia...
2007 CHEVROLET DUALLY PICKUP TRUCK (A59905)
2007 CHEVROLET...
