antonio carraro
/ antonio carraro #1
stuart b
south maclean
antonio carraro
i have an old carraro tractor and cant find what model or how old it is can anyone please help me
/ antonio carraro #2
is there a frame or engine plate with a little more info. we could consider?
how about a plate behind the positive battery cable?
I have a factory trained french friend in Canada that's a mechanic on the current model years and maybe he can help if he had more info.
/ antonio carraro #3
That's quite a classic you have there.
Looks like an Antonio Carraro Maki 525 but it's not, since yours has the VM 2 cylinder Air cooled engine and the Maki has a single cylinder engine. I'll keep digging.
/ antonio carraro
I have a french friend in Canada that's a mechanic on the current model years and maybe he can help if he had more info.
the plate behind the pos terminal is so worn you cant see a thing but i think its around 74/73 year but not sure number on the block is 2001026 if thats any help
/ antonio carraro #6
I will check on monday when the shop is open.
otherwise maybe the factory can steer you in the right direction??
info@antoniocarraro.it
/ antonio carraro #8
The Maki 546 and 525 are odd as I thought Antonio Carraro tractors were just 4wd, equal sized tired, articulated tractors. Something new all the time!
Stuart B and ptsg
/ antonio carraro #9
Copied parts book including both Maki 525 and 546.
  • Antonio-Carraro-serie-SM-Tigre-Tigrone-Supertigre-Tropical-Tigrecar-Unicar-Unitrans-Maki-Parts...pdf
/ antonio carraro
here is a picture with the bonnet on
/ antonio carraro
thanks everybody for the help i now know what it is just have to find the bits and how tos lol
2017 Peterbilt 320 T/A McNeilus Front Loader Garbage Truck (A64556)
2017 Peterbilt 320...
2013 Kubota BX2370 44in 4x4 Compact Utility Tractor Mower (A61572)
2013 Kubota BX2370...
2008 KENWORTH T800 DAYCAB POLE TRUCK (A65643)
2008 KENWORTH T800...
16in. Skid Steer Track (A65640)
16in. Skid Steer...
2025 58in Padfoot Vibratory Roller Skid Steer Attachment (A64553)
2025 58in Padfoot...
500 gal Poly Fertilizer Tank (A66408)
500 gal Poly...
