Starlink
/ Starlink #3,601
I had a Zoom meeting today from noon until 1, had buffering several times.
Well, that's annoying. You seem to be pretty adept/expert at computers and networking, but in the interests of potentially debugging Starlink issues, can I ask some dumb questions?
Have you looked at your Advanced Debug data, (Settings, Advanced, "Debug Data") for things like;
Dish data:
PopPingDropRate,​
FractionObstructed, (both should be close to zero, if not actually zero)​
PopPingLatencyMs​
AverageProlongedObstructionDurationS, (and Interval) The first should be short, (under 1sec) and the second should be long) At the moment for me, the first runs around .5sec, and the second is running 6hours (21,600s). I.e. Starlink has had one .53 second outage in the last six hours. That's not long enough to stutter zoom.​
Router Data:
PingDropRate should be zero, if not you probably have a hardware or cable issue​
PingLatencyMs should match the Dishy PopPingLatencyMs number.​
If the obstruction numbers aren't zero, then while the freeze is definitely Starlink's doing since it couldn't see the satellite(s), it is also site specific and addressable. The Dishy/router custom connectors can spark or corrode if not 100% fully seated, or if exposed to humidity or water. They have a lot of power flowing through a relatively small connector.
There is also the potential other causes, e.g. local WiFi, or Ethernet issues, and of course, your device failing to prioritize zoom. I have seen all of the above be an issue. As @BigBlue1 mentioned above, even something as simple and seemingly benign as kinking a cable can cause issues, sometimes permanently.
All the best,
Peter
/ Starlink #3,602
All the best,
Peter
When I installed my dishy, it was pointed north and I had zero obstructions. About a month ago my dishy changed and is now pointed east and I have obstructions every 2 minutes, but my speeds are faster. It is pointed at some trees, but due to shoreland zoning here, I can't cut or trim them. I would rather have the slower speeds and no obstructions but Starlink doesn't seem inclined to put it back.
I told my neighbor how to access the additional wifi info on his MacBook so he could see what channel his units were on, what frequency, what Tx speeds were and how much noise he was seeing. Haven't heard back from him yet to see what his test results looked like.
/ Starlink #3,603
I'm assuming didn't have an issue when it pointed more north, but you are having more issues now that it's moved? Not counting being faster as an issue. :)
Mine was always, "2 minutes obstructions" because of trees and a ridge that pokes up to the north of here. I assume that is why i get buffering at times, but it seems worse in the evening, more like an oversubscribed ISP or service. I didn't really notice it getting worse, until reading post here. I got mine during the beta period, when the service was getting faster and better because of more sats.
I connect directly to Dish via ethernet back to firewall.
My high usage devices except one are wire connected. PC, Nvidia Shield, SiliconDust DVR and "smart" TV wired. I have a SiliconDust ethernet attached TV Tuner connect via point to point, it take OTA TV and sends it to DVR or NVidia Shield, has very little Internet traffic, mostly xml TV schedule.
I haven't actually kept track of "downages" but it does seem to be a bit worse in the evenings, when i'm assuming higher traffic either ISP or streaming services.
/ Starlink #3,604
I think this may be the highest that I have seen with my "best effort".
/ Starlink #3,606
Received our Residential? kit and we have been getting between 130-168 on the download when run on a 5G phone.
It drops into the 30-40s when run back to back on my old laptop.
So I guess wlan in my laptop is old and slow and just limits speeds.
/ Starlink #3,607
I just found this video about setting up a secure connection to your resources inside your network, like a VPN, but uses Cloudflare Tunnels. Does it without poking holes into your firewall and should work with CGNAT like Starlink. I haven't tried it out yet.
Cloudflare Tunnel Easy Tutorial
VPNs are a great business. Easy to deploy, low risk, high profit & easy to promote on YouTube. For most users though they do little for security at best & create the very security hole they claim to fix at worst.
Many of the cheap VPN providers actively snoop on their users data, log things they claim they don't & provide a nice centralized location to collect data to sell. A large number of these VPN providers are located in China or other locations that have espionage issues with the West.
For consumers it just encrypts your data between your machine & the VPN provider. If you don't trust your ISP there is value in that. But that data is then running across the rest of the Internet outside of the encrypted tunnel for the rest of the connection. If your app isn't properly encrypting its traffic these days, you really need to get rid of it. It's massively insecure & a VPN won't help.
Personally I use a VPN at DEFcon, who pretty accurately claims to have the the most hostile network in the world. But I don't anywhere else, even the free airport WiFi.
There can be value to spoof your location for streaming services & to bypass region locks. But that's a pretty small use case.
VPNs do have value for corporate systems, but they are quite different in their deployment & usage in ways that home users wouldn't get value. This is roughly analogous to the video. It's a bit more complex to get a VPN into your home network. You may not need to open holes on your firewall in the traditional sense. But if you can get into your network, an attacker can use a similar method to do the same unless you are really ontop of setting up & maintaining things correctly.
/ Starlink #3,608
Sure. BTW did you check out the info about Cloudflare Tunnel?
/ Starlink #3,609
/ Starlink #3,610
How old of laptop? Is laptop connected via wifi or ethernet? Wifi standards could have been less capable if it is quite old.
/ Starlink #3,612
Very likely
I'm paying $55/ mo for 100GB up/down fiber landline. My Dell laptop, 2019 has a wireless modem that limits the speed to 50GB, which I routinely get, my phone, same vintage, sometimes gets 108GB. So it is very likely limited by the chip in the laptop.
(The laptop looks like it will be the last one in a long time that I will be able to get with 8GB RAM/1TB hard drive for $200 :( )
/edit , my big mistake - the speeds were supposed to be Mbps not GB
/ Starlink #3,613
It is at least 11 years old low end 15" HP
yes just wireless connection
I should replace this thing.
The phone is one of the more recent 5G models Pixel 5a
/ Starlink #3,614
Very likely
We talking speeds not data limits right?
I was thinking anything over 40 Mbps down would be plenty for me/family and was happy to see the Starlink was at least this fast which is better than what the Mobley generally can do. was very happy to see the phone show well over a hundred Mbps down
Wow fiber is fast if the first character changed from an M to a G
/ Starlink #3,615
"Whoa, It Worked" :D
👍 Good 1st test with only few satellites up so far
October 24 2019
Elon's comment when they tried the first actual test.
Well it sure took long enough for availability
but glad we were finally able to get service.
Wow this thread sure took Off, just like a Falcon 9 :)
/ Starlink #3,616
Very likely
Just to keep stuff accurate, he means 100Mb/s, he could not afford 100Gb, nor does he have the hardware to utilize it.
/ Starlink #3,618
Makes sense. The good news is that even 35Mb/s will allow you to do pretty much anything you need, so it isn't like the laptop is useless.
/ Starlink #3,620
The conduit for fiber I put in on my street in November is now active. $79.00/month for first year(300mbs) then $107/month after that. Not sure what I'm going to do.
2010 Kia Soul SUV (A66738)
2010 Kia Soul SUV...
2016 Chevrolet Silverado 2500HD 4x4 Crew Cab Knapheide Service Truck (A68183)
2016 Chevrolet...
2019 WESTERN STAR 4900EX SLEEPER TRUCK (A67714)
2019 WESTERN STAR...
2014 Ford Explorer AWD SUV (A66738)
2014 Ford Explorer...
2017 Freightliner M2 106 Auto Crane HC10 5 Ton Crane Service Truck (A61573)
2017 Freightliner...
2006 Ford F-350 12ft. Flatbed Truck (A61573)
2006 Ford F-350...
