Grooming Mower Spindle Issue
/ Grooming Mower Spindle Issue #1
TN8Man
Tennessee
TYM T494C, EA Root Grapple. JD445
I have a Titian Implement (now IronCraft) SGM grooming mower that needs a new spindle. I have the new spindle and in the process of removing the old one but I can't get the GUK SELF LOCKING NUT to budge that holds down the pully on the top side. I've sprayed some penetrating oil on it but it won't budge. Any suggestions on how to remove this nut?
Here is why it needs to be replaced. Stripped threads when the blade hit a tree root.
/ Grooming Mower Spindle Issue #2
Put blade back on tight. Put a chain on end of blade to deck or frame. Put wrench on pulley nut. Hit wrench with hammer. Use a 4x4 block, or tie it to truck bumper and drive away. I have used all methods.
/ Grooming Mower Spindle Issue #4
You could try and grind 2 flat spots on the stripped thread to be able to get a wrench or vice grips on there. Or maybe weld a nut on the end to get a ratchet on to hold against the other nut..
Just a couple of suggestions. Perhaps someone else here can also chime in with more.
Hope this helps!!
The threads are stripped so I can't put the blade back on. I do have a wrench securing the spindle from moving.
Hope this helps!!
The shaft on the bottom does have two flat spots already and I have a large wrench holding it in place.
/ Grooming Mower Spindle Issue #8
Definitely go with air tools. I went with air tools years ago after busting up my knuckles too many times, and dealing with extending wrenches with pipe etc...
Yeah, I ended up with a big scrape/bruise on arm when the wrench slipped. I'll pickup the impact sockets tomorrow morning.
My mower deck has left hand threads to hold the pulley on, worth a try.
Good point. I've made that mistake before but this time I looked closely at the threads to make sure it wasn't.
Thank you all for the help! I picked up the right tools this morning and was successful in removing the nut. The impact wrench was rated at 1,200 FT LBS and still took about 15 seconds to break loose. But its off!
/ Grooming Mower Spindle Issue #14
My Astro Pneumatic Thor 1/2" impact will bust any nut anywhere and if it don't it will twist the shaft apart.
213088 (A64276)
213088 (A64276)
UNUSED FUTURE STB47 TELESCOPIC BOOM (A65055)
UNUSED FUTURE...
(10) UNUSED SDLANCH RS3803-1.5" RATCHET STRAPS (A65055)
(10) UNUSED...
New/Unused Electric Winch (A65583)
New/Unused...
John Deere 2840 Tractor (A64047)
John Deere 2840...
UNUSED FUTURE TB47 FORKLIFT TELESCOPIC BOOM (A65055)
UNUSED FUTURE TB47...
