Pull out the choke, turn on the ignition, step on the starter
   / Pull out the choke, turn on the ignition, step on the starter #1
bcp
Super Star Member
SW WA
Kubota BX2360
When is the last time you did that in a car or truck?
i remember doing it as a normal part of driving, but can't remember what car it was.
Bruce
   / Pull out the choke, turn on the ignition, step on the starter #2
Daddy's 1958 GMC pickup was that way!
David from jax
   / Pull out the choke, turn on the ignition, step on the starter #3
I remember doing that, needed about four feet . One for gas, one for clutch, one for brake and one for starter !
   / Pull out the choke, turn on the ignition, step on the starter #4
My 58 Nash has a choke & pull starter. It has a mechanical fuel pump will pull lever, so sitting a long time I manually pump filling carb, pull choke and accelerator pedal about 6 times...starts right up.
   / Pull out the choke, turn on the ignition, step on the starter #5
My Ford 9N tractor, except I had to use my hand instead of my foot (does that count?).
   / Pull out the choke, turn on the ignition, step on the starter #6
1949 chevy one ton, last time started in 1976. It had an abused life and died that year.
Bruce
then to the boneyard.
   / Pull out the choke, turn on the ignition, step on the starter #7
My 47 willys jeep, except the button was on the dash. Man before that, it could have been a wheat truck i was driving as a kid, i can remember that, but im sure there were some afterwards. I remember rocking my foot over onto the accelerator while stepping on the starter
   / Pull out the choke, turn on the ignition, step on the starter #8
By the time I started driving most American cars had "automatic" chokes. Floor the accelerator pedal before starting to turn the choke on (and put some raw gas in the carb from the accelerator pump), then after it starts and is somewhat warm, blip the throttle once to let the choke go back to regular position so the idle would drop to normal. Sometimes it would go in steps.
My first two cars were foreign cars that had manual chokes. On one you had to get it in just the right position or it would not start at all.
I still sometimes blip the throttle on an engine that's warming up to get the idle speed to drop, just out of habit. Modern FI works so much better.
   / Pull out the choke, turn on the ignition, step on the starter #9
My first car (1962 Falcon, bought in '67) had a manual choke, everything else had automatic. It had vacuum wipers too as I recall. Getting an automatic choke adjusted just right could be kind of a PITA since you generally had only one chance a day when the engine was cold enough.
How much to pump the accelerator varied from vehicle to vehicle. On a Ford you had to pump it 2-3 times, try that on a Mopar and you'd flood it.
+1 on that!!!!
   / Pull out the choke, turn on the ignition, step on the starter #10
My 49 Willys Overland had the starter on the floor, 3 on the tree with dashboard overdrive. What a tank. 50 top speed in OD.
   / Pull out the choke, turn on the ignition, step on the starter #11
Lot of them had 5,36 gears. Some had 5.13 ratio.
   / Pull out the choke, turn on the ignition, step on the starter #12
520 Johnny popper, Super M Farmall, H Farmall, from 60s thru 86 when we sold the last one. Don’t remember if 52 Ford with flat head had starter on the floor though.
   / Pull out the choke, turn on the ignition, step on the starter #13
My father’s 1949 KB5, although I don’t remember ever driving it.
Every time I saw him start it cold though he would get it rolling backwards out of the barn, slip the clutch and it would start immediately.
His Ford 4400 was also like that.I got it going after it had been setting for about 5 years. Then we sold it. :(
   / Pull out the choke, turn on the ignition, step on the starter #14
Funny you bring this up because I just did it NEVER. Are we talking airplanes.
   / Pull out the choke, turn on the ignition, step on the starter #15
My Dads 39 Plymouth. We drove across the country pulling a home made trailer. Times were lean then.
   / Pull out the choke, turn on the ignition, step on the starter #16
Last was an old Gravely. Probably last car/truck was an old Studebaker.
   / Pull out the choke, turn on the ignition, step on the starter #17
I did it in my first car, a 1929 Model A ford coupe.
Plus several more after that.
   / Pull out the choke, turn on the ignition, step on the starter #18
59 Chevy 2 ton truck had the floor starter,
WD Chalmers had a pull rod to engage the starter,
Farmall 560 and 656 have push buttons on the dash.
Lots of other vehicles with manual chokes, some had the auto chokes removed and manuals installed.
   / Pull out the choke, turn on the ignition, step on the starter #19
Last time I did that was in 1971 driving my dads 1927 Model T Ford.
   / Pull out the choke, turn on the ignition, step on the starter #20
My Dads old Plymouth also had the high beam switch on the floor.
DEUTZ MARATHON...
2011 Toro Workman HD Utility Cart (A59228)
2011 Toro Workman...
2017 FORD E-350 SUPER DUTY 16' BOX TRUCK (A60430)
2017 FORD E-350...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
2016 Ford Transit 350 Cargo Van (A59230)
2016 Ford Transit...
